Dash backlight and radio cuts out over bumps
Old Feb 23, 2021 | 07:55 AM
The Beaves's Avatar
G35
Originally Posted by The Beaves
So I'm new to this forum. And this sweet car! 2003 g35. I just got it yesterday and have a issue. if I hit a bump. All dash backlights go out. Stuff like cruise control light still works. And the radio is just. Off. No sound no nothing. Itll "turn back on" of you hit another bump. Any ideas?
Bad or loose ground connection, poor connectivity in a wiring harness connector, corrosion in a wiring harness, did anything get wet at one time?
You need to do a careful inspection.. Have a multi-meter handy so you can start tracing when it happens.
Download the FSM for your vehicle and start at the fuse that controls the dash lights.
It is simple electric tracing battery and ground
Good luck
Old Feb 23, 2021 | 09:14 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Hah, I see what happened there Yes it's probably a loose wire, follow Telcoman's advice.
Old Feb 23, 2021 | 02:10 PM
The Beaves's Avatar
G35
Good luck
I dont know about the water. Like i said. I just bought this car two days ago. Where would the ground I'm looking for be? And I'm guessing a FSM is a factory service manual?
Old Feb 23, 2021 | 06:41 PM
cleric670's Avatar
BANNED!!!
Here's a link to Nicoclub who hosts the FSM's for free.
https://www.nicoclub.com/infiniti-service-manuals
Old Feb 24, 2021 | 09:57 PM
The Beaves's Avatar
G35
Good luck
also I cant trace as it happens when driving
Old Feb 25, 2021 | 05:53 AM
telcoman's Avatar
Veteran: Army
Follow the FSM and check every connector in the wiring harness.
Check every pin for voltage where it should be.
Check every pin for ground where it should be.
Any corrosion anywhere?
You may very well stumble upon the source?
Good luck
Old Mar 1, 2021 | 03:27 PM
Oldsled's Avatar
Sedan with Bose, Sport Suspension
If it is a stock Bose unit, they were recalled because of a circuit board issue. I have 3 2003-2004 G35 and they all have upgraded HU’s now. Hopefully just the loose wire causing it, not that it’s a fun gremlin to chase.
baileyrx
Archived Sales
Oct 25, 2009 08:50 AM
4everinfinity
May 22, 2009 05:48 PM
theprophet
Archived Sales
Nov 22, 2006 03:04 PM
