Rod knock
Old Jul 9, 2021 | 12:15 PM
Chuckd33z's Avatar
M.o.d.s - Muffler Delete . Megan racing exhaust tip. Cats delete Megan racing test pipes
Rod knock
I have a 2006 G35 x i completely underestimated this project my awd is shot out i was driving the car wit out being in use i am fixing a rod Knock ive already located the knock am changing all bearings minus well my upper oil pan has a hole so am also need to replace that question is can i install the oil pan wit out putting on the awd assembly or do i need it on ? Or can a rwd upper oil pan be a same fit. ?
Old Jul 9, 2021 | 08:25 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
RWD and AWD oil pans are different, AWD pan has a hole in it that the right side CV axle goes through.
You might be able to patch the hole in your existing pan, welding to cast aluminum is tricky but it can be done.
GrayG35
Nov 15, 2016 12:54 AM
SinisterSntra91
Drivetrain
Oct 29, 2014 10:07 PM
RedBaronK
Feb 19, 2011 06:57 AM
Texasscout
Jan 5, 2009 05:10 PM
str8dum1
Forced Induction
28
Mar 18, 2008 04:36 AM
