Rev up to de swap
Old Sep 23, 2021 | 06:38 PM
Mikeylunday35's Avatar
06 mt rev up sedan
Rev up to de swap
I have a 06 sedan mt rev up engine that’s blown beyond repair so decided to swap to de I have a engine that’s out of a automatic 02-05 g35 area not sure what year I’m about to start rebuilding so my question is what do I need for the swap I have original harness and ecu atm to the rev up engine
Old Sep 24, 2021 | 12:26 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Do a google search for "g35 rev up to normal / regular de swap" there's a few threads out there.
Personally I'd just use the donor short block and swap over the heads from the rev-up. Rebuild them if needed, new head bolts, new timing chain, gaskets, rev-up oil pump, reuse the rev up oil pan baffle.
Then you don't have to screw around with all the other stuff and you keep the rev-up engine. The only difference between the regular DE and the rev-up is the oil pump, heads assembly, oil pan baffle. Technically the connecting rods are "different" in that the rev-up ones can handle about 20 extra whp before bending, unless you're boosted this isn't an issue.
Old Sep 24, 2021 | 04:41 PM
06 mt rev up sedan
Thank you for the information will be helpful for me sounds easier then the swap itself lol so will probably go that route to avoid headaches
Alex Lorden
Mar 24, 2021 10:10 AM
Mosesg35
Feb 2, 2020 11:20 AM
Kyle Seward
Apr 18, 2019 05:38 PM
SleepySixSeven
Forced Induction
Apr 22, 2018 10:46 PM
ResurrectionG35
Apr 29, 2014 08:14 PM
