Abs sensor for g35 sedan
Old Sep 14, 2022 | 01:25 AM
QX1's Avatar
QX1
Is V35 G35 sedan -base front right abs sensor same as coupe sensor? Oem part suggests only coupe. And put at infiniti oem parts online it says your part does not fit your car? but choosing part to sedan it goves same part to sedan as is to coupe? has anybody some experience? OEM:47910-AL50A.
Old Sep 14, 2022 | 07:55 AM
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
Do you have an AWD or RWD sedan? That part number is for coupes and RWD sedans, as the reluctor ring is part of the front wheel hub. AWD cars have it as part of the axle half-shaft.
Edit: I just noticed you mentioned yours was a "base" which I'll take as RWD, so that part should work.
Old Sep 14, 2022 | 01:04 PM
QX1's Avatar
QX1
Yes my car is RWD sedan 6MT with sport suspension and limited slip differential. V35. VQ35DE
Has anybody any experience with Holstein abs sensors, they suppose to be better than OEM?
Old Sep 17, 2022 | 10:37 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
ABS sensor fortunately is one of those parts that most manufacturers have figured out how to make correctly. You can run pretty much any brand but those Holstein ones do appear to be an OEM quality component and they have a 3 year warranty.
QX1
Nov 29, 2023 07:50 PM
QX1
Sep 10, 2022 08:49 AM
David3100
Apr 29, 2016 04:21 PM
chowdogg
Apr 2, 2008 07:21 PM
