Moog Endlink Hits Control Arm
Old Oct 30, 2022 | 01:53 PM
G35CO's Avatar
I have 03 G35 Sedan with sport suspension, Stillen swaybars set on the soft setting, and stock ride height.
I replaced the stock front endlink with Moog endlinks and I noticed that the new endlinks hits and rubbs on the control arm. It started to scrape some of the metal from the control arm
Anyone else having this issue? Any ideas on how to fix it?
Old Nov 3, 2022 | 10:53 AM
LexD's Avatar
I would purchase the OEM endlinks and re-install to solve this issue.
Brand: Nissan
Part #:
54618-AL502 - RH
54668-AL502 - LH
Fits models: 350Z / G35
https://www.z1motorsports.com/front-...nk-p-3708.html
Originally Posted by John_R
... The Moogs are considerably thicker and the studs longer than stock and needed to jack up the knuckle a fair bit to get Moogs in place. In addition to the bracket that acts as a stop against the sway bar when you tighten the upper stud, there's also a 6mm hex detent in the upper stud on the Moogs that you can use to stop it from spinning as you tighten.
https://g35driver.com/forums/brakes-...-critical.html
Rainy
Apr 27, 2021 05:08 PM
maniacmotomouth
Sep 12, 2016 08:39 PM
Wannabe6MT
Apr 19, 2010 09:21 PM
mpapers
Sep 4, 2008 01:38 PM
