G35 Sedan V35 2003 A/T "VDC, SLIP & Service Engine Soon"
Old Dec 9, 2022 | 04:55 PM
hrousey's Avatar
Helping my boy fix blow engine
Exclamation G35 Sedan V35 2003 A/T "VDC, SLIP & Service Engine Soon"
Recently did engine swap. Supposed to have 150K. Changed all 3 Cam Shaft Sensors with sensors. Runs great and no more oil leaks.. Thank you lord.. When getting ON IT pedal to the medal type stuff. He gets these lights. Checked codes and camshaft sensor code comes up only. Also he got couple used tires for the rear and the are a size smaller than the front.
Topped brake fluid and still happens. I know his emergency brakes are no good... And wow was I surprised to find out about the emergency brakes being completely separate. Any ideas or helpful thoughts would be greatly appreciated..
Thanks in advance G Enthusiast,
Latest Code
P0327
Raw code: 0327
ECU: 10
Status: Pending
OBDII: Knock sensor (KS) 1, bank 1 - low input
Infiniti: Knock Sensor 1 Circuit low Input (Bank 1 or Single Sensor)
File Type: txt
text.txt (248 Bytes, 46 views)
Old Dec 16, 2022 | 05:31 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Replied to your other thread.
prada.robot
Feb 2, 2020 01:59 PM
Tillfinity
Oct 22, 2017 04:14 PM
Mendiesel
Jun 19, 2015 01:43 AM
s14lenny
Jun 16, 2015 08:04 PM
koreycon
Apr 28, 2015 09:58 PM
