i kno i know another wheel question
Old Mar 13, 2005 | 12:15 AM
gthirty5blak's Avatar
i posted this in tires but i need some SEDAN OWNER HELP the rims im looking at are 20x8.5 with a 35 mm offset all around... im not sure about that offset on the rear has anyone ran that offset before or hurd anything about it, also tire recomendations im pretty new at this so any help or info could go along way
Old Mar 13, 2005 | 02:12 AM
Gsedan35's Avatar
Front is a non issue. Rear will be fine to as long as you stick with a 245 tread width (it's actually slightly more clearance then someone running a 9" wide rear with a 38mm offset).
Old Mar 13, 2005 | 02:13 AM
hksjza70's Avatar
you really need to do some searching around. with 19" wheels 9.5" +42 rear is max, and 8.5" +38 front is max. +35 will stick out. I ordered my 20's 8.5"+38 and 9.5" +44, they're supposed to be in this coming week. shouldn't have any issues.
Old Mar 13, 2005 | 09:13 AM
Wingsprint's Avatar
35mm??
35mm on a 8.5 wheel will more than likely stick out further than the fenders. There is a few guys running 38mm on 8.5 wheels and their wheels are totally flush with the fender, any less (35mm) I am afraid will stick out and possibly cause rubbing-especially if you ever lower the car!
For reference here is a picture of my 05 Sedan with 8.5 wide wheels with a 45mm offset. Just imagine how they would look sticking out another 10mm.
https://g35driver.com/forums/attachm...tid=7047&stc=1
Old Mar 13, 2005 | 10:40 AM
alright i def want to drop so this is out of da question im assuming, alright ill be sure to post as soon as i find anotha set that i like
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Detailed Image
Jul 24, 2015 12:31 PM
