G35x timing cover
Old Jul 29, 2023 | 12:48 PM
Samoneil612's Avatar
G35x automatic sedan
G35x timing cover
Hey all, new to the forum but having an issue thought I'd ask around. I have a 2004 g35X and am trying to replace the timing chain. I have the cover all loose (yes I got the bolts in the oil pan) but can't get it fully off. The bracket on the passenger side that holds the idler pulley and power steering pump is too close to the cover and I can't get the cover off enough to actually pull it out. It looks like the bracket bolts are buried deep under the exhaust manifold and I really don't want to go through all that when I'm this close. Not sure if this specific to the AWD or not but any advice is appreciated before I just cut the bracket in half.
Old Jul 29, 2023 | 09:51 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
There are two bolts at the bottom that are accessible with the oil pan removed. Don't forget those two.
Fortunately the entire Factory Service Manual for these cars is available at Nicoclub. They pay for the licensing on the FSM, you don't need an account to access it. I strongly recommend you download the entire FSM for your specific car.
Section EM - Engine Mechanical will have teardown of the engine.
https://www.nicoclub.com/infiniti-se...ls#g35_g37_q40
Old Aug 1, 2023 | 11:48 AM
Service manuals
The service manuals make no mention of timing chain service.
Old Aug 1, 2023 | 01:32 PM
Urbanengineer's Avatar
:Confused:
the service is replacing the chain and all the components one chain would touch. Pretty much the only part not changed is the variable intake gears.
Old Aug 1, 2023 | 01:35 PM
I know how to all that, the only trouble I'm having is actually getting the cover off because that bracket is in my way.
Old Aug 1, 2023 | 02:51 PM
Gotcha. Options include lifting the engine with an engine support bar or hoist after loosening engine mount crossmember nuts. This may give you enough room to get the bracket off
Old Aug 2, 2023 | 10:01 AM
Yeah I'm not doing all that, just cut and weld
redpearl99
Dec 17, 2011 10:24 AM
856_reilly
Oct 7, 2011 12:46 AM
kennymo
Oct 16, 2010 07:29 PM
cliffords
Aug 7, 2009 02:00 PM
04Gwhiz
Oct 30, 2006 07:59 PM
