Air bubbles
Old Oct 4, 2023 | 12:31 AM
Beginner's Avatar
Infinity G35 Sedan
Air bubbles
My 2003 G35 started to overheat so I looked under the hood and back where the coolant bleeder valve is 2 of the hoses was hanging in the air unattached due to bleeder valve breaking from being brittle so I replaced it but have been getting bubbles out for 2 days and am hoping to learn what I'm doing wrong
Old Oct 4, 2023 | 11:54 AM
Urbanengineer's Avatar
Bleed coolant air according to the manual.
get the front end raised up and put in a spill free funnel. It takes some serious time to break the air bubbles out of the VQ.
Old Oct 5, 2023 | 06:16 PM
Beginner's Avatar
Infinity G35 Sedan
I did all that and it gets bubbles out until coolant boils and starts to get everywhere so I turn off car and wait a few hours and try it again and less bubbles come up but heater stays cold and it never stops burping up bubbles. Is it better to drain the whole thing and fill it back up and burp it?
Old Oct 5, 2023 | 07:54 PM
G2B35AGN's Avatar
Coolant needs to be added very slowly. Search @cleric670 for his method of taking car out and slamming the brakes to dislodge bubbles. Rinse and repeat until things are working.
Old Oct 5, 2023 | 09:10 PM
Beginner's Avatar
Infinity G35 Sedan
Unfortunately I can't do that because the car over heats within 30 seconds of attempting to drive it so back to the ramp and burp technique I go
Old Oct 6, 2023 | 11:04 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Just time it right when the engine is warming up. When it's ALMOST at normal operating temperature drive it wide open throttle to 30mph then slam on the brakes HARD almost triggering the ABS. Make sure you have the heater on full hot with the fan at max speed, it should immediately start blowing hot air. If not do it a second time.
Old Oct 6, 2023 | 02:20 PM
Beginner's Avatar
Infinity G35 Sedan
This is after burping it?
Old Oct 14, 2023 | 01:57 PM
cleric670's Avatar
BANNED!!!
This IS burping it.
cleric670
12
Jun 18, 2022 01:48 PM
hoon
May 3, 2022 12:45 PM
itseddie
Nov 1, 2016 11:54 PM
ArchAngel777
Aug 15, 2013 11:18 AM
G35_sylvi
Jan 17, 2009 08:46 PM
