Anyone know if you can do an ac compressor bypass?
Old Jan 23, 2024 | 06:56 PM
Oni's Avatar
Oni
07 Infiniti G35S
Exclamation Anyone know if you can do an ac compressor bypass?
Hi, I would greatly appreciate any suggestions for this issue.
I drive a 2007 G35S, sedan post-facelift model. I was driving today and my ac compressor bearing seized and I had to pull over, the car won't run without it. I got it towed back to my house. I'm really short on funds and cannot really pay for an ac compressor replacement from a dealer. I was wondering if anyone had done an ac compressor bypass so the car could run without ac? I do not have access to a lift but I think I can access the ac compressor and the belt top-down. I would really appreciate any suggestions, I have found alot of videos on ac compressor replacements but not really for bypasses.
Best, Oni
Old Jan 28, 2024 | 09:44 PM
Oni's Avatar
Oni
07 Infiniti G35S
Just wanted to write an update in case anyone encounters this post with the same issue, this worked for an 07 Infiniti G35S, with the VQ35HR engine (one serpentine belt for everything).
The ac compressor pulley can be bypassed with a NAPA Auto Parts belt, number 060500 (sometimes 25-060500). Its a 6 rib belt instead of a 7 but its cheaper and fits on well if its centered. I used a 50 and 3/4 inch belt, it might be slightly tight so maybe could have done with a belt around 1/8 inch bigger but everything moves nicely. The car is running fine so far and I found the belt advice from an old forum, the guy used it for his 350Z and said it had been working for 3 years with it.
I just had to pop the air intakes, coolant reservoir, and rad fans. If you want lots of room you could probably pop the rad as well but this way I didn't have to bleed the coolant system at all or touch anything but the res. Oiled up the tensioner and held it with a breaker bar. Only difficulty was the belt had to be rolled on by manually turning the crank, just had to make sure to manually roll it back before starting the car to take up any slack which may have been created in the timing chains. This may have been because of the belt being a bit tight, one a bit bigger like I mentioned and you could probably just heave it on the pulleys, but rolling it hunted it onto the pulleys perfectly (belt also was pretty cold so if left by a heater or worked through the hands for a bit and it may have loosened up). Rolling it also set off some engine codes for camshaft and crankshaft locations as their locations didn't match from when the car was turned off, I just cleared the codes with a scanner, when I ran it they didn't reappear at all. I also did not remove the ac compressor because I didn't have the equipment to properly discharge the system and didn't want to damage the system with rapid depressurization because I plan to replace the compressor eventually. Only thing I did remove was the lefthand (driver) side idler pulley, right next to the compressor pulley, because the back of the belt seemed a bit at risk of rubbing. Whole process took about two hours, and I just used sockets and some pliers (specialty pliers for removing pop tabs and the like to remove sensors and access everything as well).
42N8one
Apr 21, 2011 03:36 PM
hotdamn
Oct 7, 2010 11:17 AM
robinchen
Nov 19, 2007 02:07 PM
