Is it my starter?
Old Mar 1, 2024 | 07:09 PM
05_Blue_G35's Avatar
Is it my starter?
2005 Sedan, new battery, won't start. I turn the key and lights and everything come on like normal but there's no click and car doesn't turn over. This happens a couple times. I turn the key again (3rd time now) and the car starts and runs like normal. Is this the starter or something in the key cylinder/ignition? I drove the car and it was fine, then parked at home. I went back to it later in the day and it wouldn't start again--same thing, turn the key, lights all come on, but no click and no cranking. Starter?
Old Mar 2, 2024 | 06:29 AM
Scorpi0's Avatar
It could be the starter or the starter relay. Those are most likely.
Old Mar 2, 2024 | 08:51 PM
I'll start with the relay, thanks. Is there a particular part # for the relay? I'm searching but not finding a part #.
Old Mar 3, 2024 | 08:34 AM
Scorpi0's Avatar
It should be under the hood, installed on the IPDM. U can actually swap it out with one of the other similar relays on the IPDM just for testing purposes. And if u do realize the relay is bad, your local auto parts store should have one available.
Old Mar 3, 2024 | 04:14 PM
It was the stater. The only one available today (needed the car fixed ASAP) was a reman Carquest from AAP. Got it swapped out, not a bad job at all, and it fires right up again. Hopefully it lasts.
G35boot
Oct 9, 2021 03:30 PM
needhelp1
Jan 17, 2018 11:56 AM
336G35
Dec 1, 2014 08:52 AM
an2ane
Jul 5, 2014 02:30 PM
slim17265
Jun 11, 2014 03:43 PM
