car will not start....see below
first time it would not start I checked battery connections, (good) finally started on 7th try....
one week later..same thing....this time it took 29 tries with KEY before it would start....anybody having had this problem..I am betting on ignition switch or key fob....help
g35 03 6 speed manual..(62000 miles).and yes the clutch is all the way down with no carpet under it.
As Jon said need more info. I had thisproblem on my old camaro and it ended up being my starter. I replaced the selenoid first hoping it was that, but to no avail. Replaced the whole starter and never did it again.
Mine made kind of a click followed by a whiirrr noise from the bottom of the engine.
turning key produces nothing, no click, engine does not turn over
I'm not sure how car behaves if it's a chip in a key. I don't know if it's cranks the starter, but does not start the car. I could check later tonight, I have couple keys without chip.
If it cranks, but does not start, you can be sure it's a starter, but if it does not crank (without the chip) it could be you key (chip)
condition, now fob will not open the doors...but still opens trunk...took it to Infiniti dealer after about 30 min of trying could not open doors...fob battery checks out good
now have to lock doors with key.
have now purchased the switch under the dash which recognized that clutch is depressed....Dealer says that it will be very expensive for THEM TO FIX
Not sure what kind of button you are talking about, but did you have them check the starter?
they did not check starter,,,on the same day I had pulled all fuses and they all checked gook...I disconnected battery for 30 min....no problems since....with starting....the fob still does not work on doors, need to use key....fob will work on trunk only after I use key on doors to get in...
update...a week ago I noticed the alarm came on when trying to enter (car was not locked) a click on the key fob stopped it. .since I have pulled all fuses to check disconnected battery there have been no problems.
the dealer now says he thinks someone was trying to steal the car.
update..the thought is now that an attempt was made to steal car and the electronics went into imobilized mode...yesterday key fob opened trunk and pass side door. car has been starting fine ever since I remove and cleaned fuses and reinstalled. disconnected batter for some time.
update...today the key fob now opens all doors and trunk....the demons have been repelled
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
marsman328
Northern California
Aug 11, 2015 07:29 PM
