Need input re: brake calipers
Old Apr 17, 2024 | 11:37 AM
timothymiles's Avatar
2004 G35X
I need to replace my left real brake caliper. I decided to replace the other rear one too. I'm trying to keep the cost down so bought two different brands. When they arrived, I realized they are not the same even though both are the correct part. I don't mind having them look different unless that's a problem. Please let me know if both these, despite their design are fine or not. Thanks
Old Apr 17, 2024 | 11:46 AM
Urbanengineer's Avatar
They’ll both likely work.
One came with the bracket and the other did not, or are you talking about the slightly different castings?
Old Apr 17, 2024 | 12:55 PM
Oh.. I get it now.. the bracket is a separate part.. damn.. missed that completely. So.. can I reuse the bracket that's currently on the old caliper or do I need to/should replace the bracket at the same time?
Old Apr 18, 2024 | 11:46 AM
HoserG35's Avatar
G35 6MT “Brembo Car”
If you rebuild the bracket and put new boots on, sure you can reuse it. Make sure to lube it properly with Syl Glide or something similar or else you’ll chow the new pads up. Make sure to replace the hardware and lube the pad contact points.
ocn
Aug 3, 2017 01:26 PM
youngdip631
Jun 18, 2015 10:39 PM
CokeWave
Nov 6, 2010 02:57 PM
ProfanityPete
May 31, 2009 07:04 PM
