05 g35x NEED HELP ASAP
Old Aug 16, 2024 | 10:38 AM
aliycat's Avatar
G35x 3.5L V6
Hey guys I really need help. I have an 05 g35x sedan and recently within the past week she has been shutting down on me. At first she was riding fine about 2 weeks ago but within the last week she started jerking only at around 1st-2nd gear, but then she started having trouble going uphill from full stop like she’s trying to breathe. I took a look at the air hoses and found that the air intake boot hose is completely cracked and not even attached to the throttle body. I’m just wondering if i replace the cracked boot hose, would that fix that problem essentially? Or should i go ahead and replace the whole stock air intake with an Z1 cold air intake. And her service engine soon light came on. please help!
Old Aug 16, 2024 | 04:23 PM
jbarnett250's Avatar
Either of those solutions would help. If you have a huge air leak after the MAF sensor, the car is going to run like crap. You can either replace the accordion section that's torn or replace the whole thing with a Z1 piece. You just need to be sure you have no air leaks after the MAF sensor.
Old Aug 16, 2024 | 05:38 PM
aliycat's Avatar
G35x 3.5L V6
Thanks I ordered the piece and now I wait till Sunday when the piece comes in. I will update after I get the accordion piece. Also should i go ahead and clean the throttle body while i’m at it? And i should do the whole relearn procedure for all of those after right?
mberd
Intake & Exhaust
12
Jun 21, 2018 05:22 PM
G35DarkKnight
Dec 3, 2012 02:54 PM
neve
Canada
May 13, 2011 09:15 PM
baileyrx
Jan 21, 2005 07:06 PM
