Sedan w/ 19s
Love the setups guys...
Maybe a repeat request but, can you please post rim widths, offsets, and tire sizes??? I just sold my coupe, and got a sedan, and I'm terrified about the rim sizes... please clarify.
Joe
Joe
tires are 245/40/19......rims are 19x8.5 +38 offset all around....
the Tein H-techs are for the G35 Sedan and it dropped the fronts to 1.4 and the backs to 0.7....havent gotten any alignment specs since i am going to wait for them to settle.....
I dunno if I am posting in the right forum but anyone know if the stock sport suspension for the '03 sedan can handle a lowering spring set? Or do I need to get new gas shocks?
Also, do I really need to get coilvers or are spings ok if I am not going to adjust my ride height?
Originally Posted by Ts916G35
if i wanna to get 225/40/19 tires for 19x8.5 whee (front)and 255/35 /19 for 19x9.5(rear).. 38offset for all 4 wheel
Would they Fit?
thanks for help...
Would they Fit?
thanks for help...
I love it. Not much stiffer then stock (sport suspension), improved handling, great look. There is still some body roll, but I plan on installing Stillen sway bars. I do have slight negative camber in the front (rear is fine). I have about 5k miles on the tires and I can see a bit more wear on the inside edge. I plan on getting the 350EVO camber arms. I know they're pricey, but I'm looking long term. $850 camber arms vs. $1300 tires.
I highly recommend the Tanabe NF210s I just put on my 05. It rides so good, its unbelievable, definetely smoother than stock, with huge improvements in handling/cornering capabilities. Coupled with my Toyo T1S', I'm absolutely loving it.
Skeloton_cru... any springs you might recommend or which ones to stay away from? You think I will need the camber kits for a 1"drop?
Anybody with Tein springs on their sedan care to chime in here?
CandlestickPark
Southern California
May 7, 2008 07:12 PM
