sedan 19s pre-lowering
Old Feb 13, 2005 | 11:28 AM
tkman00's Avatar
hey guys,
do any of you have pictures of your sedan on 19s before dropping it? i have to convince myself out of 19s since i don't plan on lowering any more than .5 inches using coupe suspension. i'm almost set on going 18s, but i just need to get that last inkling of desire out of my head. also can anyone recommend a tire and offset combo for 18x8.5f/18x9.5r?
thx
Old Feb 13, 2005 | 10:42 PM
Gsedan35's Avatar
Run the front offset at 38mm and in the rear run a minimum of 45mm, anything up to 55mm is fine. 245 wide in the front with 275 in the rear is popular if your going for the staggered look, though you should try and take pains to keep the rolling diameter front to rear as close as possible. If someone wanted to their's no reason why a 255/40-18 front tire can't be run.
Jusseth
Sep 13, 2020 12:25 PM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
TheKnite
Aug 14, 2015 07:59 PM
chinee
Aug 8, 2015 10:11 AM
teamghost
Jul 28, 2015 04:52 PM
