how much to lower
Old Mar 28, 2005 | 01:38 PM
deniszr298's Avatar
how much to lower
i want to lower my 03 sedan , i woud like to know how much can i lower the car and still be able to get it aling with out a camber kit , i got stock wheels with sports pakage , thank you
Old Mar 28, 2005 | 02:04 PM
dklau33's Avatar
If you drop the car less than an inch you should be able to get the alignment specs back into factory specs although it may be at the extreme end of the spectrum depending on how low. If you drop more than an inch you won't be within factory specs for some or all of the alignment settings depending on far over an inch.
Old Mar 28, 2005 | 04:49 PM
SoCalTed's Avatar
I've got the Eibach pro-kit... 1.1" in the front and 1" in the rear. You will need an alignment after, but you should be able to get very close to spec without a camber kit. Without an alignment you will wear out your tires prematurely.
-T
Old Mar 28, 2005 | 05:27 PM
gq916's Avatar
i have tanabe springs...1.5'' drop in the front and 1'' in the rear..i got allignment 2 months after i got my springs...it was pretty close to factory specs and i know for sure that i am not having any tread wear...
Old Mar 28, 2005 | 05:44 PM
deniszr298's Avatar
thank you all for the replay
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
DRG35R
Jan 31, 2016 07:14 AM
