reattaching splash guards
Old Mar 29, 2005 | 08:41 PM
dirrtybear's Avatar
raises all-in
My front splash guards have pebbles stuck between the part that adheres to the lower trim which created separation between the guard and the body. The part of the guard by the wheel well is screwed on, but the "back side" is stuck on by some kind of adhesive or glue.
Is it advisable to remove the splash guards to get rid of the pebbles then reattach it? Or, do I risk damaging the paint underneath?
TIA!
Old Mar 29, 2005 | 09:48 PM
Z2G's Avatar
Z2G
the adhesive tape is 3m tape and binds pretty good. try unscrewing the screw(s) to loosen up the part. then try to remove the pebbles. if you have to take off the splash guards, you may need to heat up the adhesive first with a blowdryer. when you re-install the guards, you will need to purchase more 3m tape.
Old Mar 29, 2005 | 09:54 PM
dirrtybear's Avatar
raises all-in
Great! I'll give that a try. Thanks for the tip!
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
Kelvin Style006
May 23, 2016 03:47 AM
jbmw002
Sep 10, 2015 12:54 AM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
laksjd84
Jul 24, 2015 05:12 PM
