synthetic oil yes, no?
Old Apr 5, 2005 | 01:49 AM
mrb's Avatar
mrb
Originally Posted by BobbyG123
Ya know, I've begun to question the value of synthetic oil. Don't get me wrong, I do believe that it works "better" than traditional motor oil. I also believe that if you use castrol 5w-30 and change it every 3,750 miles (per the manual) that you will have no problem getting at least 150K solid miles out of your G35.
I've owned two Nissan Maxima's, and both of them were/are going strong on conventional motor oil. Obviously changing the oil regularly is far more important that what type of oil you use. My dealer uses a synthetic blend (5w-30), so all the better.
Do some research on the subject and you'll find that synthetic withstands heat much better, and offers far superior protection compared to dino oil. You also get extended intervals to go along with the added protection. 15k mile intervals with a filter swap in between are a reality now, even in a performance car, and that is with better protection than regular motor oil.
Old Apr 5, 2005 | 06:44 AM
JustBrilliantX's Avatar
Misanthropic nut-cracker
From: On the water at the "Jersey Shore"...Toms River
Switched over to Mobil 1 at 1500 mi. w/a K&N filter. Dumped first load at 4,000 miles and plan to change every 5,000 thereafter. I also do a Blackstone oil test (with TBN) every other change. Don't buy into the concept that you can't start early w/synthetic and that ya gotta "break your car in" first. Most every big hp. euro/American exotic (Viper,Vet,Masseratti,Ferrari,etc.) on the market comes with Mobil 1 already in place. I've always run synthetic in my auto transport tractors and my personal vehicles with great success. I actually put over 250,000 miles on a Ford Festiva "commutation special" and sold it ...only to see it make another 80,000 mi. See ya
Old Apr 5, 2005 | 09:08 AM
RJP6's Avatar
Lucky me,
I work for a synthetic lubricant company so I can do a infrared analysis,
among other tests, to see how the oil is holding up. Synthetic is "by far" superior.
RJP
Old Apr 5, 2005 | 03:21 PM
SAL9000's Avatar
Originally Posted by vegasG35sedan
Im getting almost due for my first oil change. I have always been a fan of synthetic oil years ago but how many of you use it in your infiniti,, if no, why not?
Since I stick with the recommended viscosity and change intervals, no I do not use synthetic.
Synthetics can provide a wider range of viscosity (like 5W-50 or similar) that may be required by really high performance engines for various reasons like bearing velocity, bearing material, bearing clearance, etc. Also, synthetics can survive tough environments better (like heat, contamination, etc.) but if your using the recommended oil and change intervals, you won't get the benefits of synthetic if your manual doesn't require or recommend it.
Old Apr 5, 2005 | 04:00 PM
Homeslice's Avatar
Was this you?
[IMG]X[/IMG]
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
