Replacement Battery
Old Apr 12, 2005 | 05:25 PM
gdupg35's Avatar
Replacement Battery
Any suggestions for a good replacement battery for my sedan? I don't drive the g a whole hell of a lot these days and it sits for long periods of time. I also have a stereo with a 1300 watt amp and a 400 watt amp which haven't helped much in the demised of my o.e. battery.
Thanks!
Old Apr 12, 2005 | 06:17 PM
SilverII's Avatar
diehard from sears....those are pretty good!
Old Apr 12, 2005 | 07:35 PM
JSuppi's Avatar
I figure you can never go wrong with Interstate (Mega-Tron), the green top batteries.
They are a little bit pricier than the Diehards (like maybe 5$ depending on the model) but I have much better luck with them on previous autos that I have had, and especially the ones with an upgraded aftermarket soundsystem.
Old Apr 12, 2005 | 09:07 PM
spendgy's Avatar
I would look into an Optima replacement. However, I'm unsure of the fit. I'm sure someone has tried it though.
Old Apr 12, 2005 | 10:20 PM
G35Mechanic's Avatar
If you buy a nissan badged battery from a nissan/infiniti parts department it is an interstate battery. The battery from the factory is an in house nissan product.
Old Apr 12, 2005 | 10:45 PM
Texasscout's Avatar
Exclamation
I can vouch for the Optima "yellow top" battery. I run one in my company Exploder. I have two 150 watt driving lamps (12 amps each), two 50 watt fog lamps (5 amps each), two 110 watt back up/work lamps (6 amps each), I upped the regular low beams to 65 watt and the high beams to 80 watt. I have a Escort 8500, telephone, map lights, aftermarket stereo and sub woofer, and the usual compliment of electric windows, locks, Air Conditioning, etc. I also run a ton of Ham Radio gear, two rigs, motorized antenna, etc. I leave the ham gear on over the weekend some times and it would drain the huge Motorcraft battery dead. The Optima yellow top doesn't even flinch.
The yellow tops are a combination of a "starting" and "deep cycle" battery. They have HUGE reserves.
Frankly, I can't believe yours has lasted this long with 1700 watts of system in it! I would thing that you would need to run two batteries with a high powered system like yours. Alot of Ham operators run to batteries when they run an amplifier with there radios.
Old Apr 12, 2005 | 11:56 PM
gdupg35's Avatar
What retailers carry the Optima "yellow top" battery? I need to pick one up tomorrow.
Old Apr 13, 2005 | 12:11 AM
R2 V35's Avatar
Thanks!
Optima Yellow top D34/78 is what I have. For sure it will last much longer than the OE battery. Check your local stereo shops or go to Sears I know for sure they'll have it. Goodluck!
Old Apr 13, 2005 | 08:50 AM
Texasscout's Avatar
They are avallable at "Sam's Club". About $130.00
Old Apr 13, 2005 | 12:04 PM
JSuppi's Avatar
Weight?
If I recall correctly aren't the Optima Yellow Tops not suggested as a starting battery? I think the Red Tops are OK but the Yellow where not. I could be mistaken, but I think I talked to someone who sold both types and they mentioned it really depends on how you use it.
Also just a side note, if I recall correctly (it's been at least a couple of years since I had a yellow top in my Exploder) the Optima's are significantly heavier than a regular automotive battery so I don't know how that would affect the weight balance of the G.
Old Apr 13, 2005 | 04:08 PM
gdupg35's Avatar
Thanks
Appreciate the replies!
chinee
Jun 10, 2024 07:48 PM
jsimonk
Dec 22, 2023 03:49 PM
dimentio1
Aug 16, 2015 11:47 AM
chinee
Aug 8, 2015 10:11 AM
