Quality of weatherstripping
Old Apr 17, 2005 | 10:13 PM
ABQ_G35's Avatar
This is the second time I have had an issue with the weatherstripping around the driver side door, there is a tear in it, same place as the first time, the first time the dealer thought it was due to them removing my driver seat, and they ripped it, nothing had been done recently of that nature, so I'm wondering if anyone else has had an issue with this. It's the rubber in the door opening, not on the door itself, I mean sometimes I brush that area with my leg, a pant leg shouldn't do that if it's made properly, right? Never had an issue like that on any previous vehicles.
Old Apr 18, 2005 | 04:49 AM
skeleton_cru's Avatar
Sedan
I have this issue as well. I finally figured out that it was just me brushing it when I entered the car. I'm a big guy so if I'm not careful I'll rub the weatherstripping pretty hard when I get in the car.
Old Apr 18, 2005 | 09:49 AM
Philly_G35's Avatar
I noticed the same problem with my weatherstipping. I then realized it was from me rubbing against it when I entered the car. I am 6'-3" so my seat back it actually behind the door post. I have since been more careful and I have noticed it hasn't gotten any worse.
Old Apr 18, 2005 | 09:56 AM
G35sedanman's Avatar
My drivers door weatherstripping also tore on its seem. They replaced it. However, since new, I have noticed that the drivers door needs extra force to close it as compared to the other doors. Otherwise, I don't get a complete shut.
Old Apr 18, 2005 | 11:03 AM
ABQ_G35's Avatar
Yes, but shouldn't that be designed to accomodate that? The angle of the door makes it hard to avoid contact. I'm going to try again to get it replaced on warranty, we'll see!
Old Apr 18, 2005 | 12:13 PM
Deang35c6's Avatar
You're driving a rebadged JDM vehicle. Japanese aren't big people.
Old Apr 18, 2005 | 12:57 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
I stopped using the seat memory.
Since this is only a single axis memory, I don't find it all that usefull anyway.
I actually find it easier getting in and out with the seat in it's
normal position. (a little forward of the max rear position)
Old Apr 18, 2005 | 09:13 PM
ABQ_G35's Avatar
I took the car by the dealership today, they are replacing it under warranty. I may try moving the seat a bit forward for exit, but not sure I can, I need al the room I can get for exiting, due to a bad leg!
Hmmmm, what about s Sumo Wrestler, not big?
Old Apr 19, 2005 | 04:28 AM
Sedan
Ditto here. I drive with the seat all the way back as well.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
the93owner
Oct 4, 2015 09:40 AM
1Typhoon
Sep 25, 2015 08:45 PM
