gtech proRR
Old Apr 20, 2005 | 02:15 AM
vegasG35sedan's Avatar
05-G35 Sedan 5AT
gtech proRR
Hey every one.. I just got the Gtech Pro-RR . My car is stock right now but I plan on doing some mods in the future and using the Gtech to gauge the HP gains (or lack of).
If you have played with one you know that you have to set your cars redline on the Gtech.
Does any one know what the redline should be set at on the 2005 5AT?
The Infiniti web site dont really advise you of the actual redline.
Old Apr 20, 2005 | 10:47 PM
05-G35 Sedan 5AT
Well I found the answer.. in case anyone else needs to know according to Technosquare, the chip reprogramers, the rev limiter is set at 6600 rpm.
Old Apr 26, 2005 | 12:37 PM
HillBilly's Avatar
Thanks for the rev limiter post. Thats just what I was searching for.
What did you use for your weight?
Old Apr 26, 2005 | 02:39 PM
UtorontoG's Avatar
I just got the G-Tech Pro RR as well...have you tested it out yet? what type of hp and tq numbers are you getting?
Old Apr 26, 2005 | 09:02 PM
notenuftoys's Avatar
If the rev limiter is 6600, then my tach is off. I've (accidentally) bounced off 7000rpm a couple of times. The surprising thing was I didn't hit the fuel cut-off.
Old Apr 29, 2005 | 03:16 PM
05-G35 Sedan 5AT
I havent got to play with it too much but I used the weight on the Infiniti website plus 1/2 take of gas @ 6lbs per gallon and my body weight 200lbs.
I cant find a nice even, level road that is long enough to reach 60+MPH safely. I may have to take it to the track. The HP that I did get showed about 157HP. Keep in mind that that is neither real wheel HP or Engine HP.
Old Apr 29, 2005 | 03:32 PM
Hyde's Avatar
Played with my friends G-Tech Pro competition. dunno the excact model but the newest one.
i got 421HP and 419Torque, 0-60 in 5.2s and 1/4 mile time of 12.3s
wanna guess what i got under the hood? its all HKS
Old Apr 30, 2005 | 03:20 AM
05-G35 Sedan 5AT
well either your blown, supercharged or the G-tech needs recalibrated
Old Apr 30, 2005 | 09:24 AM
UtorontoG's Avatar
yeah im pretty sure im calibrated properly and im getting about 160-170 hp consistantly
Old Nov 16, 2006 | 05:30 AM
tylersphile's Avatar
Scientific Intake Gain Measurement
I have a 2003 G35 Sedan
Full Tank (without me): 3580, weighed on two seperate scales.
Intake measurements (Same day weigh, 2nd gear tests WOT from 3500 to 6700 rpm, same staging points, flat, opposing directions, 10 runs per test, 4 degrees temperature differential, 94 octane, fuel and driver weight corrected):
In chronological order over 4 hour span
Test One: Bone Stock Car - Plotted in Black
Test Two: Removal of Stock Air Filter (Filterless) - Plotted in Red
Test Three: AEM Intake (only mod from stock) - Plotted in Green
Test Four: Bone Stock Car
Test Five: Removal of Stock Air Filter (Filterless)
Test Six: AEM Intake (only mod from stock)
I wanted to ensure the accuracy of my results, thus, the re-testing of each of the 3 setups. These tests mirrored the results from the first 3 tests within very small tolerances.
60 Samples Taken - Best Average Representation from Tests 1, 2, & 3 plotted
AEM:
- No obvious difference from stock below 5300rpm
- Between 5350 and 5800rpm, AEM did NOT perform as well as filterless stock in majority of samples (18 out of 20), averaging 2HP drop below filterless stock.
- Largest gains over stock and filterless stock airbox between 6200 & 6700rpm, averaging 3.5HP.
Observation: Big Gain in free flowing filter in Stock Airbox. Worth while modification. Similar Gain with AEM CAI, relative to filterless, with the AEM gaining output at the very top end and loosing some in the middle.
In conclusion: The stock intake with a free flowing filter will offer VERY similar real world performance characteristics as that of the AEM Cold Air Intake. Major differences inlude the AEM's throaty growl under high load, as well as the risk of water inhilation and engine damage.
Old Nov 16, 2006 | 10:55 AM
ttrank's Avatar
Grocery getter
That's cool. Nice work.
I have an Gtec SS but have only put it in the car once. I don't think it does all that stuff.
Old Nov 16, 2006 | 11:26 AM
ORANGEBSRT's Avatar
my loaner fuel cut starts at 7000 rpm
Old Nov 16, 2006 | 10:46 PM
HwyDrftr's Avatar
tylersphile, have you done any testing with the headers and exhaust?
Detailed Image
Aug 19, 2015 08:38 AM
godmans
Misc. G35 Related CDN
31
Mar 23, 2014 11:43 PM
danyboy
Dec 19, 2010 05:33 PM
soundmike
Archived Sales
Jun 22, 2010 04:38 PM
infinitialex
Jan 7, 2007 07:14 PM
