19" Tire Pressure
Old Apr 20, 2005 | 09:32 AM
frnsic4's Avatar
19" Tire Pressure
Hey just put some 19x8.5 HP Evos on my G35 Sedan. I am running Hankook K104 Ventus 245/35/19 all around. What would be the recommeded tire pressure to run. I have searched the forums with not much luck. Any feedback would be much appreciated.
Old Apr 20, 2005 | 10:05 AM
jaspergtr's Avatar
start with about 40 lbs, and then season to taste.
Old Apr 20, 2005 | 10:15 AM
frnsic4's Avatar
Thanks.
Old Apr 20, 2005 | 10:25 AM
R2 V35's Avatar
40psi is kinda high no? I know a lot of ppl are running 32-35psi.
Old Apr 20, 2005 | 01:13 PM
SilverII's Avatar
i'd do 35psi
Old Apr 20, 2005 | 01:51 PM
frnsic4's Avatar
So anywhere between 35-40 would be good from my understanding.
Old Apr 21, 2005 | 05:32 AM
gq916's Avatar
i do 40...save gas baby!!!!
Old Apr 22, 2005 | 11:42 AM
BlackGSedaN1027's Avatar
Yeah I'm @ 36-38psi
Old Apr 22, 2005 | 03:22 PM
frnsic4's Avatar
Thanks for all the input.
Old Apr 23, 2005 | 05:15 AM
skeleton_cru's Avatar
Sedan
40 psi seems kinda high to me. Try 35 or lower.
Old Apr 24, 2005 | 01:03 PM
G35sedan03's Avatar
I run 35psi on my 19s. To me that seems the best setting. Ran 40 as well but it didn't feel as good as 35 all around.
Old Apr 24, 2005 | 03:35 PM
kegels's Avatar
Why would you not follow the recommended tire pressure of 30psi?
Old Apr 24, 2005 | 06:06 PM
G35sedan03's Avatar
the recommended tire pressure is for the stock wheels, in my car were the 17 inches. Rule of thumb is for every size you go up, you should also increase the psi by 2 or 3 more pounds per size. I'm sure there is a more accurate way to measure that, but this is what i've read here as well what has been told to me from other driders at the meets i go to.
jsimonk
Dec 22, 2023 03:49 PM
Danielek
Sep 20, 2015 12:08 PM
JoeMac
Aug 20, 2015 10:17 AM
