shocks and spring on sedan
Old May 5, 2005 | 12:58 PM
joes954rr's Avatar
Ricmalaz
Thanks for the info. SO you ran 350Z springs and shocks right? just took some stock 350z suspension and bolted it up to the G... sounds cool. Thanks for all the feeback on the ride and handling. I definitely want the front a little lower than the back and my 20s are on order. Looking forward to the 1" front and .5" rear lowering.
Much appreciated feedback!!
Any ETA on the 350z shock replacements? Should they wear out faster on the G? Same?
Joe
Old May 5, 2005 | 03:02 PM
ricmalaz's Avatar
Yes - 2005 350z springs and shocks. Bolted right up. I used Gsedan35's awesome instructions at https://g35driver.com/forums/showthr...ion#post278721 and also at http://www.g-owners.com/article_read.asp?id=12 as a guide.
I don't know about the life expectancy on the Z shocks. All I know is my old shocks had about 30k miles and the replacements had about 1.2k miles, so I should be good for a while.
Originally Posted by joes954rr
Ricmalaz
Joe
Old May 23, 2005 | 11:22 AM
joes954rr's Avatar
Thanks for the DIY link. GOt them on this weekend. No complaints what so ever. Good ride, a little firmer, and the drop is perfect.
Thanks again for all the feedback and info. Much appreciated.
Old May 23, 2005 | 12:20 PM
dirrtybear's Avatar
raises all-in
How about some pics with the 350Z suspension? I'd love to see what the ride height looks like.
Old May 24, 2005 | 04:27 AM
Gthree5 6MT's Avatar
Hey all...
I like keeping things "in the family" too...as in, using parts from the factory whenever possible.
However, on this topic of suspension...which springs to couple w/ what struts...why don't you consider aftermarket?
I know there are alot of inferior quality, cheaply made stuff out there...but, there are also quite a few really good products...only difference is: they COST MORE.
I totally believe in the "high end" true Japanese brands such as Tein, HKS, APEXi, Espelir, Tanabe for suspension. Also, Eibach and H&R are German manufacturers who've been in the business for a long, long time...and have proved their quality products. With just these 6 brands I've mentioned, you should be able to find the right springs for what you want in height, as well as stiffness.
Also, if you really don't mind spending a little more...Tein & HKS & APEXi also offer complete coil-over sets which allow you to adjust the ride-height exactly how you want it. Plus, those are all really good handling units! I have the Tein HA c/o's on my Miata...and, since the dampening is 16-way adjustable...I can set them to soft for everyday commutes, or turned pretty stiff for hard driving.
My two-cents...^-^
Old May 24, 2005 | 09:00 PM
ydlee24's Avatar
Originally Posted by Gsedan35
You double posted this in the tire/wheels/suspension section of the board, I replied to that post.
I have a 03 Sedan NON sport suspension do I just need the 350z springs to lower an 1 inch? And I have 20's all around will it rub? Or can I go with Eibach pro kit is there a difference with the pro kit and 350z springs?
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
reavensf
Sep 17, 2015 11:30 PM
si_driver
Aug 11, 2015 07:08 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Scredeur4
Jul 17, 2015 06:30 AM
