Coupe Midpipe PROBLEM
Old Apr 28, 2005 | 09:36 PM
turq's Avatar
Cool Coupe Midpipe PROBLEM
I just recently had the coupe midpipe installed on my 04 6MT sedan. The sound alone is definately worth the $100 bucks (thank you Pinoy).
But there seems to be a slight problem. Besides the midpipe i have a injen CAI. I never had any problems with my CAI, but im having a problem with the midpipe. Any time i really get on it my emergency brake light, VDC, and Slip light all come on, and stay on. The car doesnt drive or handle any differently at all though. Could this be because the ECU is not used to having so much air goin through the engine with the CAI and midpipe? Anybody else have this problem with there midpipe? I dont know if just need to do a ECU reset or what. I have an appointmment to take my car to Infiniti to have it checked out. But if the problem is fixed with an easy ECU reset, i dont want to take my care back to the dealer. Has anyone else had any similar problems like this after the install? Any feedback is greatly appreciated.
Old Apr 29, 2005 | 07:20 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
I don't have CAI...
I have a Z tube on the front end
& NFC Y-pipe, coupe midi, HKS rear muffler
FWIW
I have no similar problem.
Old Apr 29, 2005 | 08:07 AM
cato's Avatar
SouthernComfort Moderator
What you describe sounds like the "brake light switch recall" that happend last year. Take it in and they will fix it under warranty.
Old Apr 29, 2005 | 08:51 AM
JustBrilliantX's Avatar
Misanthropic nut-cracker
From: On the water at the "Jersey Shore"...Toms River
Have been running a "Pop Charger", and a "Z" tube in conjunction with a coupe "middy" and "Stillen single rear" since back in Nov. of 04' and am nothing but pleased with NO probs.
Old Apr 29, 2005 | 10:21 AM
g35sedamn's Avatar
/\ like he said... its either the recall. or you can check under your car and make sure the ground strap is hooked up to your exhaust. im not really sure why its there but it is. its the one hooked up to the midpipe and muffler. i also had a midpipe and intake on my car along with a plenum and don't have anyproblems.
Old Apr 29, 2005 | 11:29 AM
InTgr8r's Avatar
Originally Posted by g35sedamn
...you can check under your car and make sure the ground strap is hooked up to your exhaust. im not really sure why its there but it is. ....
FWIW...
Air flow through the pipe can create a static charge.
Old Apr 30, 2005 | 08:07 PM
turq's Avatar
Everything seems to be in order under the hood and under the car. I think i have the brake light recall, i have an appointment to have it checked out this week.
So i'll find out for sure.
Old Apr 30, 2005 | 08:10 PM
cato's Avatar
Let us know what happened!
chinee
Jun 10, 2024 07:48 PM
mike730
Jan 12, 2018 04:25 PM
andyg35c1
Aug 29, 2015 03:37 PM
Black_Out
Intake & Exhaust
16
Aug 1, 2015 08:44 PM
attarday
Jul 15, 2015 04:03 PM
