starting car w/intel key?
Old May 2, 2005 | 03:41 PM
Calypsi's Avatar
Hmm I would think if the transponder is in the car then the key should start the car because it would be similar to no key at all, which is how it would normally start. Could very well be a secndary measure for thieves though.
Old May 2, 2005 | 05:38 PM
Andy77's Avatar
Well, I thought it might work. In researching alarms with remote start, it turns out to use the remote start you need to have one of your transponder keys permanently mounted in the dash in a special (?) box. This somehow lets the car start remotely. I thought if it is in the box in the dash, then just holding a transponder key near the ignition and using the wallet key might work-but it didn't. I might try it again.
I wanted to do this, because if it worked I might be able to make a non-transponder copy of the valet key so if needed, a valet could start my car, but could not get into my glove box or trunk. Otherwise, I'd have to buy a new valet key for $100-$150.
Anyone with any ideas?
Old May 2, 2005 | 08:35 PM
mhollinger's Avatar
For the original poster (whoever you were): I've attached some pictures of the key and the ignition. I hope this clarifies things.
~ Mike
Attached Thumbnails starting car w/intel key?-key.jpg   starting car w/intel key?-ignition.jpg
chinee
Jun 10, 2024 07:48 PM
Mry
Mar 3, 2023 01:03 AM
newg37
Jul 26, 2015 09:32 AM
apintojr
Jul 23, 2015 10:52 AM
kenthung
Jul 21, 2015 05:56 AM
