Cant Fill Up Tank
My car hasn't filled past 3/4 the last two times I've filled it. I told my service rep and he said its normal, and that it's happening because it's so out right now. I really didn't buy it, but I haven't had any difficulties getting to 3/4 (no consistant shutting off) just one shut off at 3/4.
I wanted to check on this board tonight to be sure, but I think this might be my problem. If it only stops once, but stops early, is that a problem with the valve??? Or is this really normal???
Not fixed for 2006
Hello All,
This is my 1st post since purchasing my 2006 G35 3 weeks ago. I have been having the same issues as you guys. I wanted to blame the pumps at Shell but I now know that its the car. I have an appointment with the dealership tomorrow and I will mention the TSB. I will let you all know if this corrects the problem. Other than that, I racked up 1100 miles and love my G.
Thanks
Brian
2006 G35 5AT Sedan Liquid Platinum
2003 SVT Mustang Cobra Coupe (Sold)
Thanks
Brian
ok,I had the same problem the other day.Mine's an '04(aero). I kept pulling the nozzle in and out 'cause I knew she would take more....
She should have swallowed what I gave her no problem........
Fixed my 06
I took mine into the dealership last week and they replaced my shutter valve and since then its been fine. 2 fill ups and no problem. I actually didnt mind handing over my 57 bux for once at the gas station.
Brian
2006 Liquid Platinum G35 Sedan 5AT
Mods: Window Tint
Brian
Mods: Window Tint
Guest
Posts: n/a
I have an 03.5 Sedan that I bought new. Never had any problems with this until I had the car taken in for safety recall. They took out the fuel tank and then replaced it. The first time I filled up, the hose clicked off before usual. I didn't think any more about it until I started up the car. The gauge read 3/4 full.
The next time I went to fill up, I was only able to put 3 gallons in the car before it clicked off. I realized that I would have to add fuel slowly and take the risk of it overfilling.
The last time I filled up, everything was fine. I couldn't figure out what was going on until I saw the postings regarding this issue. Thanks for the tip about what is going on.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
BradMD_96
Oct 6, 2015 09:31 AM
Hogbone
Sep 28, 2015 06:44 PM
