View Poll Results: Which brand of gasoline do you use.
Shell
31
25.41%
Mobil
18.85%
BP Amoco
14
11.48%
Texaco
3.28%
Sunoco
8.20%
Exxon
6.56%
Chevron
39
31.97%
Other
22
18.03%
Multiple Choice Poll. Voters: 122. You may not vote on this poll
Which brand gas do you use?
Old May 3, 2005 | 04:59 PM
jstwong's Avatar
I'm another Union 76 gas user. It is usually the cheapest in my area except for the Exxon stations [which I never buy gas from].
Old May 5, 2005 | 06:01 PM
G-Pimp's Avatar
Shell V-Power all the way!
Old May 5, 2005 | 07:02 PM
G-Force's Avatar
Nothing but Sunoco 94, highest you can get here. Plus added bonus, I believe they are the only company with 15% Ethanol where everyone else is only at the government minimum 5%.
Old May 5, 2005 | 11:17 PM
GoldSport's Avatar
Citgo is the cheapest here, I'm not payin more for that bs chevron with techron which is right next door.
Old May 6, 2005 | 09:52 AM
g35sedamn's Avatar
import tuner a while back they had a b series shoot out, and in the writing before the test they were discussing that cheveron gas actually make the most power out of the pump gases that they tested on but in order to make things fair, they said every one had to run 76 91 octane. i personally use cheveron most of the time unless i realize i need gas on the way home. shell is about 20 cents cheaper per gallon just not easy to get to.
Old May 6, 2005 | 10:59 PM
SRHTX's Avatar
Ok, each one of you are going to hate me on this one. I just go to my Kroger store and put unleaded gas into my vehicle. Honestly, I only do city driving. I drive about 3 miles to work on two streets with plenty of traffic lights. I've had my sedan since mid December '02 and it has less than 21k miles on it.
Now, when I take a road trip out of my city, I will place supreme in the tank and hall butt on the highway.
Old May 7, 2005 | 04:02 PM
yofool's Avatar
Chevron yo!
Old May 7, 2005 | 05:01 PM
FrizzleFry's Avatar
I use 76 which is up to 10%.
Straight from my manual:
Gasoline containing oxygenates Some fuel suppliers sell gasoline containing oxygenates such as ethanol, MTBE and methanol with or without advertising
their presence. INFINITI does not recommend the use of fuels of which the oxygenate content and the fuel compatibility for your INFINITI cannot be readily determined. If in doubt, ask your service station manager. If you use oxygenate-blend gasoline, please take the following precautions as the usage of such fuels may cause vehicle performance problems and/or fuel system
damage.
The fuel must be unleaded and have an octane rating no lower than that
recommended for unleaded gasoline.
If an oxygenate-blend, excepting a methanol blend, is used, it should contain no more than 10% oxygenate.(MTBE may, however, be added up to 15%.)
If a methanol blend is used, it should contain no more than 5% methanol (methyl alcohol, wood alcohol). It should also contain a suitable amount of appropriate cosolvents and corrosion inhibitors. If not properly formulated
with appropriate cosolvents and corrosion inhibitors, such methanol blends may cause fuel system damage and/or vehicle performance problems. At this time, sufficient data is not available to ensure that all methanol blends are suitable for use in INFINITI vehicles.
Old May 8, 2005 | 05:50 AM
revolutionG35's Avatar
i use chevron 91 and add pro fuel witch is supposed to ncrease mpg
Old May 8, 2005 | 08:41 AM
RBull's Avatar
Rated M
Nothing but Irving yet. Most of you guys have probably never heard of them. Privately owned compnay, richest family here in Canada now moving into northeastern US with their oil/gas divsion of company. Cleanest burning gas available where I live.
Old May 8, 2005 | 02:27 PM
PandaBear's Avatar
Where is Rotten Robbie, Love, Flying J, Pilot, Quik Stop, Olympia, and TA on the poll?
Old May 8, 2005 | 11:34 PM
RocketsRedGlare's Avatar
There's a BP Amoco a couple blocks from work that is price just a couple cents above the cheap stations. I usually fill up there and get the $2 touchless wash.
Otherwise I fill up at the country store around the corner from the house.
Every other brand in town is refined at the local Mapco refinery. It's ALL exactly the same gas, just different additives.
The best results I've had were from Texaco, but I can't afford that place unless I'm on fumes.
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
twentyeggs
Sep 11, 2015 03:58 PM
Rhinos7777
Sep 6, 2015 05:36 PM
kevintandmd
Sep 3, 2015 06:41 PM
