Good or Bad for '05 G35x??
Old May 11, 2005 | 12:08 PM
utrain12's Avatar
I went to the track in New Hemshire last friday and ran my best 1/4 mile in 14.79. I did 4 runs and my average was around 14.8. Can you guys give me some feed back and tell me if that is a good or bad time for me to run on that car.
Thanks
Old May 11, 2005 | 12:09 PM
yeahdickey's Avatar
Is your car stock ?
Old May 11, 2005 | 01:37 PM
Msedanman's Avatar
O.F. Administrator
Thanks
Sounds a tad high. Was your gas tank full, spare tire in the trunk, etc etc?
Did you brake torque to start?
If it's not broken in yet, your times will improve.
C.
Old May 11, 2005 | 03:14 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Thanks
chicagoX should be able to give U some fedback..
pretty sure he's run a few 1/4 times
Old May 11, 2005 | 03:23 PM
utrain12's Avatar
yea its completely stock, and had a spare in the back, and the gas tank was less then 1/4 left
Old May 11, 2005 | 03:27 PM
utrain12's Avatar
C.
What you mean by brake torque start??? If u mean just holding down the break and giving it gas and then dropping the break and flooring, then yea i did that. Is there another way of doin it??
Old May 11, 2005 | 05:30 PM
ChicagoX's Avatar
Don't drink and Mag Race
Not a bad time for a bone-stock G35X !
Tips: No spare/tools/crap in glovebox and 1/4 tank of gas will make you faster due to less weight. Make your runs in MM mode and you should cut another tenth. VDC OFF!
W
Old May 11, 2005 | 07:50 PM
Lip's Avatar
Lip
Sounds good to me ! I have an 05x I need to get to the track.
If you use Manual Mode, what's the ideal shift point=-?
Old May 11, 2005 | 08:09 PM
JustBrilliantX's Avatar
Misanthropic nut-cracker
From: On the water at the "Jersey Shore"...Toms River
How does the VDC being off, in an X, help in a launch? Doesn't being AWD make it moot point...no?
Old May 11, 2005 | 08:12 PM
RBull's Avatar
Rated M
Originally Posted by JustBrilliantX
How does the VDC being of in an X help? Being AWD I thought that it was a moot point...no?
There is snow and ice at that track. Didn't you know?
Old May 11, 2005 | 08:41 PM
LuckyR's Avatar
My understanding is that the traction control will go so far as to brake (not break) to maintain no wheel spin. Admittedly w/ the 25/75 launch split that is less likely but possible.
Old May 12, 2005 | 08:17 AM
utrain12's Avatar
W
ok, but when do i have to switch in MM mode??
Old May 12, 2005 | 01:27 PM
ChicagoX's Avatar
On some of the "family-run" tracks (which is a nice way of saying poorly-maintained) I break traction on the 1-2 shift. This is because the car is in RWD at this point. With VDC on, it not only switches power to the front, but works its magic(evil?) by retarding timing and possibly applying brakes.
I run in MM mode from the start. Depending on how fast your tranny is shifting (ground wires, recent reset, etc..) you want to pop the 1-2 gear change at around 6100 so it shifts right before fuel cut (~6400 IIRC). For the 2-3 an 3-4 shifts (you will have a third shift with the lower-geared "X" car) I wait until almost 6300 before nudging it into the next gear.
Another tip: air up your front tires to 40-45 psi for less rolling resistance.
W
Old May 12, 2005 | 01:40 PM
utrain12's Avatar
Thanks ChicagoX, ill keep all that in mind next time i go
Old May 13, 2005 | 02:46 PM
ChicagoX's Avatar
I have made a couple of runs in SNOW mode.
They were within a thousandth or two of the regular runs, so I don't bother now.
