05 G35 6spd Up-shift indicator (Rev)
![Question](https://g35driver.com/forums/images/icons/icon5.gif)
I am wondering if any of you guys have played with the up-shift indicator? and what was your experience?
My g35 came set to 8,000 rpm from factory, however, the manual states that it could be changed from 2,000 to 8,000 rpm. For maximum engine speed, 7,000 rpm is indicated and for maximum engine torque, 4,800 rpm is indicated. I guess 5,900 as a mid-point between the two would be best.
I am tempted to play with it but my fear is that I will mess something up since I don't have a clear idea and really have not read much in this form about it.
So your input is much appreciated.
You won't mess anything up by playing with it. It's only a light that reminds you when to shift. Setting it at 7,000 is the redline, and setting it at 4,800 is the point of max torque. Personally I find it to be kind of a gimmick.
Since your car's new, I would set it no higher than 4,000 until you're through the break-in period. You could also set it even lower, to remind yourself to shift earlier for better gas mileage. A problem with setting it low is that when you're in 6th on the highway it's constantly on.
on
What the hell were they thinking ???
![Roll Eyes (Sarcastic)](https://g35driver.com/forums/images/smilies/rolleyes.gif)
Originally Posted by dbarnes
As the owner of an '04 6MT, I thought the new "upshift" light was a cool feature, too, if maybe somewhat of a gimmick - until I realized that it's pretty much necessary on the '05, since some "genius" at Infiniti decided to swap the speedometer and tachometer from left to right in '05. This way, your left arm blocks your view of the tach (while the speedometer is clearly visible since your right arm is busy shifting). Of course, that's just what everyone needs under full throttle acceleration with an MT that is somewhat notchy and tricky with the gates, to raise their left arm (the only one steering the beast) at WOT in order to see the tach !!
What the hell were they thinking ???![Roll Eyes (Sarcastic)](https://g35driver.com/forums/images/smilies/rolleyes.gif)
Originally Posted by GeeWillikers
Sounds like you hold the wheel TDC (top dead center) with your left hand while you're rowing. Although I don't shift, I frequently steer with my left hand and have none of the trouble you speak of. 10 & 2 doesn't block anything, or in some cases 10 alone.
![Cool](https://g35driver.com/forums/images/smilies/cool.gif)
The dealer set it at 4000 for me when delivered, and I changed it to 7000 after 1200 miles. That said, I too typically block it with my left hand/arm and never see it. Guess I feel more in contol with my hand at TDC. Plus, if I'm taking it past...say 5000RPM (hauling butt)...my eyes are straight ahead and not glancing down at the tach. I'm still learning to shift by engine note/vibration so I don't need to take my eyes off what's appearing rapidly in my windshield.
on
Gangsta? Wish you'd been trying to follow me up Hwy 88 to Tahoe last week -you'd need both hands and a clear view of the tach to keep me in sight - I have never been accused of being a "laid back" driver, fellas, much less a "gangsta" (although I could be the first in your neighborhood with "spinnas" on a "G", eh?).
I double-checked, just to be sure - I hold it more like 11 on the wheel, but regardless, some blockage occurs at 10 anyway, at least in my field of vision, with my height, driving position, etc. Aren't many cars out there with MT transmissions that have the tach on the left side, guys - check it out.
No hassle intended, but I thought that with the advent of Airbags that no longer are the 10:00 and 2:00 positions advocated, but rather 9:00 and 3:00??
That said, my Driver Ed was nearly fifty years ago and I'm lucky to find the "Necking ****" on my steering wheel.
![Big Grin](https://g35driver.com/forums/images/smilies/biggrin.gif)
... Infiniti decided to swap the speedometer and tachometer from left to right in '05. ...
The Shop Manual shows the car configured for the British Right hand drive. Of course, the car was also built with left hand drive for export to the USA and elsewhere. If one went to a car show, you'd see the left hand drive cars with the Tach and Speedometer sometimes in one configuration and sometimes swapped. The arguments as to what the Brits actually exported in 1956 were argued long and fiercely, but never resolved.
As to driving with the two configurations, most of us would never be looking at either as generally we knew when to shift based on a combination of "feel" and "sound" - coupled with experience on that particular car.
It is hard to get caught up with some issues when on the road when you have but one centered stop light and brakes and a clutch that share the same fluid reservoir.
on
Originally Posted by SaltiDawg
This reminds me of an old argument that many of us that were into vintage British cars had. (Specifically my 1956 TR-3's.)
It is hard to get caught up with some issues when on the road when you have but one centered stop light and brakes and a clutch that share the same fluid reservoir.![Cool](https://g35driver.com/forums/images/smilies/cool.gif)
Sorry we hijacked the thread - back to the subject, I wouldn't mind having a "shift" light in my "G", if it's programmable like they say. Pretty good idea, IMHO.
Carry On ...........
Not a gimmick
For break in, setting at 4k was very handy.
I may turn it off later, but for now I like it.
I changed it today from 8,000 factory set-up to 5,800 and it has truely changed the car feel. l love it. Although I am aware of "expectancy effect" however, I don't think that's the case.
Would it be okay to have it set to 5,800 during my break-in period?
and what is up with the break-in period? I think it should be eliminated. It's 2005 for God's sake no break-in period for cars should be needed
![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
