click noise from drivers front wheel
Old May 25, 2005 | 04:46 PM
badtz's Avatar
Hi all,
does anyone else hear a single click noise from the driver's side front wheel area when the getting the car. It only happens if the car has been sitting for hours and when you shift your weight into the car theres a click noise. only a single click and it won't happen again till the car sits for awhile.
thanks
mark
Old May 27, 2005 | 09:56 PM
Noremac's Avatar
Are you positive that it's coming from the front? A very common click sound can be made by the rear parking brake after the car has been sitting for a while, then jostled (as in opening the door, and sitting down). It is caused by the fact that the brake is usually applied when the wheel is hot, then after it cools there is a residual stress, relieved when moved again.
Old May 28, 2005 | 02:21 AM
badtz's Avatar
positive it's the front.
Old May 28, 2005 | 05:15 AM
codeflux's Avatar
wheel bearings. have it checked out.
rezendvous420
May 31, 2020 01:26 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
kinetek
Aug 3, 2015 04:25 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
papo020
Jul 17, 2015 10:30 PM
