Fuel system and Throttle Body Cleaning
Old May 26, 2005 | 09:39 AM
khsonic03's Avatar
My dealer tried to offer this to me for $200. I am thinking I might do it myself. I was going to remove the throttle body, and clean the thing, then put it back on with a new gasket. Has anyone had this done, or done it themselves? As far as the fuel injectors, what is the difference between what they do, and running some Chevron Techron fuel treatment through the system? I have always thought that it was bad to use these fuel system cleaners because they remove the protective coating on the injectors. I am pretty sure that they remove each injector at the dealer, then run it through a machine to clean it, but what is the difference?
Old May 26, 2005 | 02:05 PM
gq916's Avatar
You wont need any kind of fuel system additive if you always get gas from CHEVRON = ) so stick to chevron..cuz its proven
Old May 26, 2005 | 02:33 PM
khsonic03's Avatar
Well, I would, but we don't have Chevron around here. I get Shell.
Old May 26, 2005 | 02:48 PM
BlackGSedaN1027's Avatar
Ouch, Shell.....
Old May 26, 2005 | 03:27 PM
ballisticus's Avatar
If you have Costco, look for the 4-pak Chevron Techron fuel system cleaner. They have it for $9.95. One bottle per tank every month or so should keep things cleaned up. The $200 dealer deal is OK as a 30K service since they hook up the cleaning system directly to the fuel rail. It cleans the injectors, intake valves, and combustion chamber of deposits. But its not really needed if you just use a good detergent gasoline, or do the fuel additive regularly.
Old May 26, 2005 | 03:56 PM
Msedanman's Avatar
O.F. Administrator
The same 'techron' additive that's in Chevron is in Petro-Can fuel here in CAnada.
If you use that consistently, the injectors should be fine.
Take of the inlet tube and inspect the throttle plate inside the T/B.
C.
Old May 26, 2005 | 05:00 PM
khsonic03's Avatar
Originally Posted by BlackGSedaN1027
Ouch, Shell.....
Are you serious? I have heard good things about Shell.
Old May 26, 2005 | 05:18 PM
shaigh's Avatar
Originally Posted by ballisticus
If you have Costco
I was told by one of the guys delivering gas to Costco that it was name brand gas (i.e. Chevron, BP Amoco, Exxon, etc), but prior to additives being added. So if you are buying their gas, go with ballisticus's suggestion of picking up the Techron also, you might need it.
Also, a high-perf. Mustang shop (Steeda) told me that running five tanks of Chevron was equivalent to a fuel injector cleaning treatment. In their words "...its that good...".
Old May 26, 2005 | 06:42 PM
infocalypse's Avatar
Actually, Costco gets their gas the same way a lot of cheaper one-off gas stations do: they buy excess/overstock. What this means to you is that one week the gas might have a specific blend of additives, and then next week the blend will be different, and the week after that there may be no additives at all. They basically buy excess gas from refineries which isn't purchased by the major gas stations, which is why it's so cheap.
Old May 26, 2005 | 07:21 PM
g35cas's Avatar
All gasoline has the same spec's. It's the additives that are put in to them that make them different. Most gasoline that has to be shipped to large cities is shipped by pipeline into large tanks, and then shipped by truck to their gas station locations(chevron, shell, texaco, etc.) The additives are added into the tanker trucks as they fill at a truck rack connected to these large tank farms. The government regulates the additives put into gasoline, and must meet standards for cleaning fuel systems. But, yes some additives are better than others, and you usually pay more for it at the pump. I wouldn't worry about fouling injectors with name brand gasoline unless your car has over 60k miles. Even then, you probably won't need to clean your injectors unless you are constantly using "bad gas".
Old May 27, 2005 | 09:36 AM
khsonic03's Avatar
So anything on that fuel system cleaning from Infiniti? I am just curious if it's worth it, or if I should just put in some Chevron Techron and call it a day. But at the same time, I have heard that those fuel cleaners strip a protective coating off the injectors. Anyone have any thoughts/knowledge/experience? Thanks
Old May 27, 2005 | 12:23 PM
I wouldnt do the dealer clean unless the car is running poorly or you are getting lousy mileage. If so, then try the Techron additive in a few tanks. If its still running poor, then take it to the dealer as a warrantee claim first. Maybe you can get a freebee.
Hasanbaloch
Feb 29, 2024 08:45 PM
G35VSHNG37
Oct 25, 2015 08:43 PM
jbelf23
Forced Induction
Oct 24, 2015 12:32 PM
03sedang35
Aug 29, 2015 07:56 PM
