Request pic: sedan in 19s Axis Milano
Old May 26, 2005 | 02:00 PM
Renesis's Avatar
as stated in topic
Old May 26, 2005 | 05:14 PM
sukhi's Avatar
Here you go...
19x8.5 front 19x9.5 rear
245/35/19 275/30/19
Attached Thumbnails Request pic: sedan in 19s Axis Milano-side.jpg   Request pic: sedan in 19s Axis Milano-g35kit1.jpg   Request pic: sedan in 19s Axis Milano-front.jpg   Request pic: sedan in 19s Axis Milano-g35kit-009.jpg   Request pic: sedan in 19s Axis Milano-g35kit-004.jpg
Old May 28, 2005 | 12:07 AM
g35333's Avatar
Your car looks nice...I was wondering what did you use to lower your car and is there and rubbing?
Old May 28, 2005 | 12:32 AM
Machine Head's Avatar
What tint do you have?
Old May 28, 2005 | 04:30 PM
bajracharya's Avatar
The tint looks like 30 in front and 20 in back ...
BTW, the silver looks fine....
Old May 29, 2005 | 01:58 AM
g35_6gear's Avatar
Originally Posted by sukhi
Here you go...
245/35/19 275/30/19
front and rear offsets??
Old May 29, 2005 | 04:36 AM
sukhi's Avatar
The tint is actually 50% all the way around. I did not want it dark.
Old May 29, 2005 | 04:38 AM
sukhi's Avatar
its a 45mm off set both front and rear. And no it does not rub. I have a hubcentric spacer on the front.
Old May 29, 2005 | 04:39 AM
sukhi's Avatar
Thanks bro..
Eibach pro kits with Dspec shocks. Absolutely no rubbing.
Old May 29, 2005 | 04:47 AM
skeleton_cru's Avatar
Sedan
Hey Sukhi, what size spacer did you use in the front? 10mm?
Old May 29, 2005 | 06:33 AM
Renesis's Avatar
these rims looks so good but they are so gawd damn heavy, 27lbs.
Old May 29, 2005 | 11:30 AM
g35_6gear's Avatar
I think he is talking about the hubcentric ring that centers the rim on the hub....not a wheel spacer that spaces the rim off the hub.
Old May 29, 2005 | 06:10 PM
Sedan
Yes, but I believe he used a spacer. With a +45mm offset in the front the wheels would be tucked in much farther then the photos suggest.
Old May 29, 2005 | 10:20 PM
sukhi's Avatar
YO Cru,
Its a 5mm hubcentric spacer. In an attempt to resolve some vibration problems after my new tires were installed, I removed the Spacer and it still did not rub even with a +45 offset. Reason is when the alignment was done, the factory a-arms were pulled slighty. I am going to put them back on because they sit too far in, not like the pictures...turns out the vibration is because of a slightly bent wheel. I need to get that repaired. Any one know any good Bay Area Shops?
On A side note, the Milanos are an "ok" wheel. Yea it looks nice, but I know I sacrificed some quality with the cheaper admission ticket. I may be searching for new wheels after the second set of rubber wears out.
late.
Old May 29, 2005 | 10:31 PM
Sedan
Sukhi,
Several years ago I had a slightly bent MOMO Arrow wheel on my T-Bird. I had America's Tire Co. fix it. Actually, they sent it out to be fixed (Where? I don't know). Anyway, they actually did a good job.
Good luck...Eloy
tiguy99
Mar 1, 2016 11:42 AM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
