Grinding at startup
Old May 28, 2005 | 09:50 AM
harley01's Avatar
Grinding at startup
I have a 05 I purchased about a month ago and swear I've heard a grinding noise at startup a couple times. It almost sounds like when you hit the starter when a car is running. Anyone else experience this? I'm taking the car in for an oil change, but since it only happens on occasion I'm afraid they will not be able to locate the problem.
Old May 28, 2005 | 10:06 AM
fullofivy's Avatar
Harley01,
Interesting...I think I have heard something similar in my 05x. The 'grinding' noise occurs at the very end after the engine has turned over. I was thinking maybe it's the exhaust manifold or some heat shield that is vibrating at engine start. Hmmm...think I will pay closer attention to it. Please let us know what your dealer finds. Thanks.
Old May 28, 2005 | 11:03 PM
wnpublic's Avatar
Have the same sound periodically, particularly at "cold" start. My service guy at Infiniti stopped me halfway through my explanation and told me it was a known characteristic of the G.....
Old May 29, 2005 | 12:34 AM
shodog's Avatar
Check your oil level guys. The VQ is a known oil burner. I complained to the service tech about the same problem. They couldn't duplicate it. I took it back and found the oild level to be low.
Old May 29, 2005 | 01:23 AM
lowchen's Avatar
Yeah, I had the exact same situation
Old May 29, 2005 | 03:51 PM
Msedanman's Avatar
O.F. Administrator
Timing chain rasp on start up until it gets some oil on it.
Typical of Nissan/Infiniti. no worries.
C.
Old May 29, 2005 | 09:28 PM
harley01's Avatar
Thanks GSedanman....that makes sense. So will you get the sound regardless of your oil level?
By the way, you need to change your name....maybe Msedanman : )
Old May 29, 2005 | 10:27 PM
shodog's Avatar
I don't hear it when the oil level is right.
magnetism80
Feb 1, 2019 10:00 AM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
alinero718
Sep 27, 2015 09:35 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
jjohns2711
Aug 5, 2015 08:58 AM
