Mobil 1 Oil Filter?
Old Jun 5, 2005 | 05:26 PM
NorCalifG35's Avatar
Question Mobil 1 Oil Filter?
Anyone here use the M1 oil filter on their G? If so, which number?
When I had my 2003 Maxima, I used an oversized M1 filter (number M105). It was bigger and held more oil than the M1 number that was listed for my engine.
Curious to know if the M105 filter fits on this engine too (since it's a similar motor). Getting close to my first oil change and definitely want to stick with Mobil 1.
Thanks
Old Jun 5, 2005 | 05:58 PM
Mr.GEE's Avatar
20 Year Member
I purchase Nissan filters from the dealer for both the G35 & Maxima and they are the same part number, so I would say you can use the same filter you used with your Maxima.
Old Jun 5, 2005 | 06:06 PM
Msedanman's Avatar
O.F. Administrator
I too used the Nissan filter from the Maxima on the G's. It's slightly larger than the OEM one.
C.
Old Jun 5, 2005 | 06:59 PM
That's great. Thanks for the info guys.
Old Jun 5, 2005 | 07:39 PM
allforthecash's Avatar
I use the Mobil 1 Filters...all the time..I never used dealer filters...i also use Mobil 1 oil....
I purchase the filters from www.everythingg35.com....
Old Jun 5, 2005 | 09:42 PM
Dudefish's Avatar
I use Mobil 1 M1-108.
Old Jun 6, 2005 | 09:54 AM
khsonic03's Avatar
I am not sure about the m1-105. I don't think that will work. The larger size that I use for my G is the M1-110. It is a size up from the M1-108 which is recommended for our cars.
Old Jun 6, 2005 | 01:32 PM
Wingsprint's Avatar
Mobil 1 M-110
Larger than the stock filter (which happens to possibly be the world smallest automotive oil filter). The M-110 fits perfect.
Old Jun 6, 2005 | 01:47 PM
Gumba35's Avatar
Same here I use the M110.
Old Jun 6, 2005 | 02:33 PM
klg35's Avatar
while on the topic of oil filters,.......is there a reason for it being so small? I thought that bigger filters would do a better job of filtering more debris.....some edumacate...
Old Jun 6, 2005 | 03:04 PM
mc2's Avatar
mc2
i'm curious too... does larger filter = better filtering?
Old Jun 6, 2005 | 04:03 PM
SilverII's Avatar
larger filter = more filtering media
does not necessarily mean it will filter better
Old Jun 6, 2005 | 07:29 PM
ballisticus's Avatar
I've been using this http://ecat.arvinmeritor.com/smartlink/?partnum=PL14610
55k miles on it now, runs like new (actually better with the mods) and great oil analysis #'s. $5.99 at Fred Meyer, Pep Boys etc.
Old Jun 6, 2005 | 07:54 PM
ckg35's Avatar
I've been using the Mobil 1 M-110. Though I don't think it filters better than the smaller ones, because of the additional surface area, it should maintain its flow better over the life of the filter.
Old Jun 7, 2005 | 08:05 AM
Wingsprint's Avatar
A larger filter will not filter better, but it will properly filter LONGER than a smaller filter.
