very hot in the car????
Old Jun 11, 2005 | 01:49 PM
LuXXXz's Avatar
i have a question, y ta **** does it get so hot in the car, it seems like the heat is on when we're driving only on the feet though, i have everything off, and it still gets so hot in the car anyone share this also????
Old Jun 11, 2005 | 02:25 PM
Andy77's Avatar
Mine does not feel hot when the A/C is on. When it has been in the sun for 10 hours at work it takes a while to cool off, but hot air does not hit my feet.
Does this happen with the system on complete Auto? If so, there could be s stuck door in the ventilation system. Do you have dual temp controls with yours accidentally set too high?
Old Jun 11, 2005 | 03:27 PM
G-Mann's Avatar
happens to me too. i have to blast the AC for it not to be hot but he AC is so loud in these cars it gets annoying
Old Jun 11, 2005 | 04:26 PM
Birdhouse's Avatar
It's Lonely At The Bottom
Arrow
I live in Vegas so I know what you mean. My windows were tinted (solargard) last monday because I couldn't take the clear windows heating up the car up to 140+ degrees and now what a difference! Now when I park it out in the sun and when I enter it's so much cooler than before. The difference is night and day and I don't have to crank the A/C like before.
Old Jun 12, 2005 | 10:13 PM
SGT's Avatar
SGT
What % tint did you get?
Old Jun 12, 2005 | 11:37 PM
Eticketride's Avatar
Here is a link to a previous post. I have not tried this fix. I just turn on the AC for a few seconds then the hot air goes away. Maybe ask your dealer about the problem? Hope this helps.
https://g35driver.com/forums/showthr...ighlight=DaveO
Old Jun 13, 2005 | 03:08 AM
G35_coupe_6MT's Avatar
cover ur car up. Thats what I do when I go to uni.
Old Jun 13, 2005 | 08:19 AM
Garnet Canuck's Avatar
Traveling Administrator
I had the same issue as you. My heat was off, however it was still blowing hot air out the floor vents. I found out that it was because the temperature was cranked as high as it would go....back from the winter time. Even though I actually had the heat turned off, it was still blowing the hot air out. Once I adjusted the temperature back down to the lowest it would go, the issue went away. I never thought it have anything to do with your temperature setting since the heat was off, but it made the difference.
Old Jun 13, 2005 | 12:17 PM
Birdhouse's Avatar
Thumbs up
Solargard: HP Charcoal - 22% front windows 13% back windows
Now I feel that this brand film is better since it cooled the car down that much.
Old Jun 13, 2005 | 08:09 PM
LuXXXz's Avatar
yeh i ran the a/c first then i turned it off but kept the temperature at 65 and the problem went away.
thanks all.
champppy
Mar 31, 2020 12:25 PM
NemesisGee
Aug 11, 2015 07:10 PM
yassy
Aug 3, 2015 12:24 AM
ClwMike
Jul 23, 2015 12:55 PM
justgotg35
Jul 19, 2015 12:33 PM
