Tire and wheel option
Jun 30, 2005 | 12:54 PM
would i notice any negative impact if i went from the factory 17" wheels on my 2005 sedan with 235/50/17 tires, to a set of factory 18" wheels off a coupe, with 225/45/18's in front and 245/45/18's in the rear? other than financial? someone is selling a set of rims/tires off their coupe and they have about 5200 miles on them. I thought it might be a cheap mod if it won't cause any problems with the ride/balance of the car.
also, do i have to have two different tire sizes? could i eventually replace them with all the same size? say the 245/45/18's. thanks.
Reply 0
Jun 30, 2005 | 02:06 PM
Quote: would i notice any negative impact if i went from the factory 17" wheels on my 2005 sedan with 235/50/17 tires, to a set of factory 18" wheels off a coupe, with 225/45/18's in front and 245/45/18's in the rear? other than financial? someone is selling a set of rims/tires off their coupe and they have about 5200 miles on them. I thought it might be a cheap mod if it won't cause any problems with the ride/balance of the car.
I have a similar question only in reverse, I want to get a set of 17" for the winter and mount a set of snow tires on them. If you’re thinking of selling your 17" wheels I might be interested in purchasing them from you, depending how much shipping is. (Seriously)
Reply 0
Jun 30, 2005 | 03:57 PM
well, as soon as i get an answer on the question i have, i will decide what i am going to do, and then i can let you know. my 17" rims are in mint condition and the tires have about 10k miles on them. they are michelin pilot xgt z4's tires.
Reply 0
Jun 30, 2005 | 04:18 PM
Quote: also, do i have to have two different tire sizes? could i eventually replace them with all the same size? say the 245/45/18's. thanks.
The coupe tires are a little too short (smaller in diameter) than our sedan. Your speedo will read like a 1 to 2 mph higher than normal. But I've seen other people install them; with the drop, the coupe's rims are nice.
About the same size when you need to replace them, I think it is a bad idea since the front rims and the rear rims are difference width.
Anyone has technical reasons behind this?
Reply 0
Jun 30, 2005 | 05:48 PM
Ah... the tires are a different size, but are the wheels a different width?
Reply 0
Jun 30, 2005 | 06:41 PM
the coupe wheels have different offset - they won't fit on a sedan.
Reply 0
