Is there anyway to replace the stock automatic shift level with something aftermarket
Old Jul 14, 2005 | 10:15 AM
mpgxsvcd's Avatar
Is there anyway to replace the stock automatic shift lever with something aftermarket
Is there anyway to replace the stock 05 automatic shift lever with something aftermarket? I see alot of info for aftermarket manual shift levers. Are there any for the automatics? I think the stock one just looks a little cheap.
Old Jul 14, 2005 | 10:21 AM
GeeWillikers's Avatar
Walking The Fine Line...
Not to be a dick, but your thread title says 'level' when you meant to say (I think) 'lever'
There are some shift ***** available and some here have done the mod. I'm not sure about the entire lever though.
Old Jul 14, 2005 | 10:24 AM
Here's the Momo I believe InTgr8r is using.
See this thread:
https://g35driver.com/forums/attachm...achmentid=1622
Old Jul 14, 2005 | 10:43 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
Yes, I'm using the Momo... as per link above.
I'll see if I can dig up a pic of it in the car at home later.
Old Jul 14, 2005 | 12:40 PM
mpgxsvcd's Avatar
Yes that is what I am looking for. Where can I buy that? Does it have the button to engage the transmission from park? Is it on top of the lever? How do you install it? Does the factory one just screw off? Or is there a release for it?
Old Jul 14, 2005 | 01:20 PM
InTgr8r's Avatar
The OEM comes off by removing a spring retainer on the bottom.
Just slide the bottom metal trim piece down to expose the clip.
The Momo has the button on top (where it should be)
When you remove the OEM, also remove the while nylon/plastic extension piece
(you don't need it)
The Momo goes on with a rubber bushing & 3 allen set screws.
The entire job <15 min.
Google Momo & you'll find a source (don't remember where I got mine)
Old Jul 14, 2005 | 01:33 PM
tgenius's Avatar
I didn't like the MOMO, instead I went with the 350z/G35c (And 04.5+ Sedan) Shift ****. As an FYI, if you go this route you absolutely MUST order the different plastic piece that the **** mounts on (it is mounted transversly to the old fat 03.5-04 ****.
Old Jul 14, 2005 | 01:41 PM
mpgxsvcd's Avatar
(you don't need it)
Thanks for the info. If you remember where you got it please let me know. Does anyone have any reccomendations for a good place to get Momo shift levers? Are the 05 Auto shift levers different from previous years? Does anyone have pictures of the previous years levers? Which one do you like best? I have an 05 Sedan will the momo lever fit on that?
xluke
Jul 30, 2016 01:48 PM
JG_G35
Accessories
Feb 25, 2016 01:44 AM
bTanz
Oct 15, 2015 02:31 PM
Thunderaan
Jul 22, 2015 07:40 PM
nervseele
Jul 17, 2015 11:21 PM
