Grounding Kit and ECU reset
Old Jul 31, 2005 | 12:55 AM
louisdarke's Avatar
I just installed a Grounding Kit and then followed it with an ECU reset yesterday. I took the car out and drove the sh** out if it and really think the car felt much smoother and quicker. I will see what else I notice or don't notice over the next few days, but I think it was a good inexpensive mod.
Old Aug 18, 2005 | 11:33 AM
DTrejo's Avatar
How did you reset your ECU? I was told you unplug the negative cable and hit the brake 5 times. How long do you leave the negative cable unplugged? I was thinking of unplugging the negative cable while installing the grounding kit and just plug it back in when I'm all done. Do you have to take any plastic pieces off the bottom of the car to get to the grounding point for the tranny?
Old Aug 18, 2005 | 11:42 AM
socalsean's Avatar
it's like pulling the plug on your computer. Just disconnect the battery and reconnect it a few minutes later. The brake pedal thing is a wives tail.....it's suppose to "drain" any power left in the system by turning on your brake lights.
sean
Old Aug 18, 2005 | 12:00 PM
RXM's Avatar
RXM
Check this thread
https://g35driver.com/forums/showthr...ight=ecu+reset
The instructions are simple but you have to work on your timing. When you count, use the "one-onethousand, two-onethousand, three-onethousand" method and you should nail it your first time or second time trying.
1. Turn key so that the car is on the on position (but don't start the motor)
2. Immediately after you turn it to the on position, count to three using the timing method I mentioned above.
3. After you count to three, floor the gas pedal five times within five seconds. So as you step down and hold on the gas as you count "one-onethousand" then let go and step down again and hold it as you count "two-onethousand" and so forth until you do it five times in five seconds.
4. After the fifth time stepping on the gas, let go and count to seven seconds.
5. After seven seconds step and hold the gas for ten seconds.
6 . After ten seconds let go of the gas and step on it again and hold it down for about 13-14 seconds in which you should see a light flash on the dash. The light will keep flashing until you turn off the car and turn it back on.
Thats the instructions I got from the thread so go there if you have more questions bc it has been beaten to death.
Old Aug 18, 2005 | 01:20 PM
LuXXXz's Avatar
whats a grounding kit??? for sounds?? or what
Old Aug 18, 2005 | 07:56 PM
Foo_G's Avatar
Florida G35 Club, Premier Member
From: Universe.Milkyway.Solarsystem.Earth.NorthAmerica.USA.FL.Tampa
designed to stabilize the electrical system which would include the ignition system. By design they are supposed to increase HP by bosting fire on the coils. Not certain yet if the G35 has CoPs or an Electronic distributor, I am on a learning curve right now.
Old Aug 19, 2005 | 12:46 AM
AgisA's Avatar
Dealer threatened warrantee cancel with ECU reset
Originally Posted by RXM
Check this thread
I cannot believe this but manager said they can trace any ECU manipulations/mods through a chip in the ECU and can trigger an engine light. However I think this is BS because Ihave done it in my Maxima numerous times. I think is helpful.
Old Aug 19, 2005 | 08:31 AM
SixFive's Avatar
The grounding wires are not about, nor do they make much more hp. Perhaps a tad..but the benefits are smoother shifting for AT's and smoother idle, easier start and smoother revs. The reasons why it works are complicated and the thread in the FAQ with the word hyperground has a massive wealth of information. It's cheap easy and makes an immediately noticable difference.
redonblack35
Accessories
19
Feb 13, 2016 11:19 AM
Machine Head
Sep 4, 2015 07:22 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
mikemf8
Sep 3, 2015 08:01 PM
Tukeeg35
Engine - Electrical
Aug 19, 2015 02:08 PM
