outside temperature sensor
Old Sep 4, 2008 | 07:17 AM
Metalp3n's Avatar
What is the DEF button we are supposed to press?
Old Sep 4, 2008 | 08:00 AM
GreenGoblin's Avatar
The goblin resurrection
defrost?
Old Sep 7, 2008 | 10:29 AM
Noremac's Avatar
These observed temperature errors are the result of a software bug in the HVAC control system. The early 2003-2004 models have other HVAC bugs as well - including the infamous "hot air" problem. The only solution that I've been able to use is the reset procedure mentioned earlier in this thread. That seems to momentarily "reboot" the software, but the procedure requires shutting off the engine (i.e. it can't easily be done while driving).
This is yet another example of Infiniti refusing to acknowledge a widely observed and reported problem, and issuing a TSB. It took them 4 years to finally admit to the compression rod problem, after many 2003-2004 cars were out if warranty (hmmm....)
Old Sep 7, 2008 | 08:30 PM
maciejk's Avatar
i get to the point where i can go down to code 51 but pressing the DEF button dosen't do nothing
Old Aug 14, 2019 | 01:27 PM
lolLiberaltears's Avatar
G35 Sedan 6spd
God bless you!
Originally Posted by hilmar2k
Just had the same problem. Temp guage said high 70's or low 80's, but the actual outside temp was 10-15 degrees higher. You need to perform a HVAC software reset, and it will be fixed. It's pretty easy, I found the steps necessary on this forum. I'll save you the searching:
1) Turn the ignition key off and then on again.
2) Immediately press and hold the A/C system's OFF button for 5 seconds.
3) Use the Temp control **** to change to code 51.
4) Press the DEF button once to view the external temp sensor's reading.
5) Press the DEF button a second time to view the internal temp sensor's reading.
6) Press the DEF button a third time to view the intake temp sensor's reading.
7) Turn the ignition off to exit diagnostic mode.
It worked for me. We'll see for how long.
Man this was a great save! Do you know what the other numbers mean? 2,3,41 ect?
SN00P
Jun 14, 2010 09:21 PM
07CA6MT
V36 General Tech Questions
Oct 30, 2008 10:41 AM
JayJay
Mar 16, 2008 08:07 AM
G35CHICAGO
Jul 26, 2006 11:38 AM
