Official '06 G35 Changes
#31
#33
Originally Posted by Minarets
i saw where Acura TL has gone down from 270 to 258....i wonder what all this is about
#35
The Newly Adopted SAE Standard (J2723)
RE: http://www.sae.org/certifiedpower/details.htm
About SAE J1349 Certified Power
Power and torque certification provide a means for a manufacturer to assure a customer that the engine they purchase delivers the advertised performance. This SAE Standard has been written to provide manufacturers with a method of certifying the power of engines to SAE J1349 or SAE J1995. Document SAE J2723 specifies the procedure to be used for a manufacturer to certify the net power and torque rating of a production engine according to SAE J1349 or the gross engine power of a production engine according to SAE J1995. Manufacturers who advertise their engine power and torque ratings as Certified to SAE J1349 or SAE J1995 shall follow this procedure. Certification of engine power and torque to SAE J1349 or SAE J1995 is voluntary, however, this power certification process is mandatory for those advertising power ratings as "Certified to SAE J1349".
SAE Engine Rating Standard Prevents Numbers Fudging (an article on how GM will use SAE J1349 Certified Power, AEI May 2005, Vol 113 No.5, p 59 )
General Motors has become the first manufacturer to certify an engine's power and torque ratings using a newly adopted SAE standard (J2723), James Queen, GM Vice President, Global Engineering, announced during his keynote address at the SAE World Congress and Exhibition in April 2005. The world's largest automaker plans to certify all of its engines to the voluntary standard, and is encouraging its competitors to do the same. The LS7 engine for the 2006 Chevrolet Corvette Z06 was certified under the new standard this month. The 7.0-L V8 unit produces 505 hp (377 kW) at 6300 rpm and 470 lboft (637 Nom) at 4800 rpm. "The new voluntary SAE power and torque certification procedure ensures fair, accurate ratings for horsepower and torque as it uses third-party certification," said Queen. "SAE technical standards level the playing field, and this certification procedure is just the latest example of the value SAE has offered over the past century." To tout power and torque ratings as "SAE-certified," engine manufacturers must have an SAE qualified witness watch over the entire testing procedure to ensure that it is conducted in conformity to SAE standard J1349. Third-party witnessing is the main provision of J2723. An existing SAE standard, J1349, spells out how the actual testing is to be done. J1349 was updated last year to eliminate some ambiguities that allowed engine makers to cite power and torque ratings higher than the engine's actual capabilities. Engine makers are free to cite power and torque figures drived from testing conducted outside the scope of the SAE standards, but they may not claim the figures are SAE-certifed. "We feel that both the consumer and industry are well served by having accurate, consistent ratings from all manufacturers," said David Lancaster, a Technical Fellow in GM Powertrain and Chairman of the SAE Engine Power Test Code Committee that updated J1349 and wrote J2723. Data from a wide array of parameters (e.g., air:fuel ratio) will be collected during testing conducted to the SAE standards. SAE will create a database and offer it to industry in different packages and at different price points.
#36
Interesting. I hadn't heard of this. Looks like a lesser example of the old SAE gross-versus-net problem they had in the '60s. When gross ratings were still in vogue back then, manufacturers often rated their engines with completely open exhausts and zero accessories -- no air conditioning compressors, no power steering pumps, etc. Sometimes they'd go so far as to yank out the water pump too and run the test in a big hurry.
When they switched to the net horsepower standard in the early '70s (or was it late '60s?), those massive 425-horsepower engines suddenly dropped 50, 100 or more rated horsepower overnight. People quickly had an explanation as to why their 400-horsepower big-block Chevy only ran a 14.3 quarter mile at 99 mph.
I wonder whether Nissan will adopt the new SAE standard and when. I hope that if the company does, doing so will help put an end to its decade-long policy of fudging horsepower numbers across its model line. They've been particularly brazen about that sort of thing since the VQ35 was introduced in MY 2002.
#37
#38
People in the Acura communities are crying about the drop in reported horsepower. They act like their cars got slower or something. It really cracks me up.
The best response to the whining was a suggestion to put a few Type-R stickers on it to regain a few more HP!
I wonder what the SAE net HP of the G35 models are. Anyone have this info?
#39
can you tell if this is a coupe or sedan? it looks to me like the sedan headlight
i'm hoping there could be some kind of retrofit with the 03-04 sedans with the projectors too, but i'm not going to hold my breath.
#40
#45
Originally Posted by Kodeslinger
yes,
but the key things is Bi-Xenon
which, unless I'm wrong, means they'll have xenon's for both low-beam AND high-beam.
Currently, the xenon is for low-beam only.
There are exceptions- Example some European market models like the Touareg- No Halogen used for the bright/passing lights.
Additionally, the new Bi-Xenons on the Z and G35coupe do not use a halogen for high beam
A lot of people ask what's the big deal? Well projectors are better in most scenarios.
Drive a car equipped with good projectors with HID and it's pretty clear literally. The good setups have very little color, at least from what I've seen.
The G with open lense has decent lighting, though a major step down from my VW Passat equipped with OEM HIDs.
The Bi-Xenons on that car were awesome. When you turned on the high beams it was almost like running day-lighters.
I miss the HIDs and the headliner from the Passat, that's about it.
laksjd84
07-24-2015 05:12 PM
