How long in time between oil changes?
Old Aug 5, 2005 | 08:37 PM
bythabay's Avatar
Originally Posted by bythabay
By changing your oil at the optimal intervals (determined by a series of oil analysis reports), you will be saving money, time, increasing engine life, and reducing pollution. Additionally, performing engine oil analysis will inform you of any hidden problems in your engine. For example:
Air leaks, which can cause an unsafe level of abrasive elements in the oil that the standard oil filter is unable to remove.
Coolant (perhaps a leaky head gasket?)
Excess moisture (too many short trips?)
Excess fuel (thinning out the oil?)
Excess wear metals (indicating a component about to fail or perhaps your oil is not doing its job)
The only approach which takes the guess work out of oil changes, is one that utilizes oil analysis. You can easily change your oil more often than necessary, but there are drawbacks. For example:
Excess engine wear (unnecessary dry starts from empty oil filter)
Higher maintenance costs
Excess time spent / Mechanic's time spent (still takes time & money)
Excess waste (some can be recycled but overall the amount of waste increases)
Even though the initial time + money investment in scientifically determining you oil drain interval may seem like it's a waste of effort, in the long run it will be worth it.
I did some more research and I have found a handful of SAE (society of automotive engineers) papers which (I believe) support my arguments regarding oil change intervals, oil analysis, and bypass filtration. Here are the papers (you can read the actual papers if you look them up at www.sae.org)
981443 : Extended Oil Drain Intervals - Conservation of Resources Or Reduction of Engine Life (Part Ii)
951035 : Extended Oil Drain Intervals: Conservation of Resources Or Reduction of Engine Life?
750827 : Vehicle Evaluation of Synthetic and Conventional Engine Oils
981444 : Advanced Synthetic Passenger Vehicle Engine Oils for Extended Oil Drain Performance
932838 : The Effects of Trip Length and Oil Type (Synthetic Versus Mineral Oil) on Engine Damage and Engine-Oil Degradation in a Driving Test of a Vehicle With a 5.7l V-8 Engine
981448 : Used Oil Analysis and Study of Oil Drain Period in Gasoline Engine
740139 : A Study of Lengthened Engine Oil-Change Intervals
2003-01-1957 : Effect of Oil Drain Interval on Crankcase Lubricant Quality
Old Aug 8, 2005 | 07:42 PM
bythabay's Avatar
The history channel is going to play (what appears to be) and intersting show related to this thread...
Lube Job.
Airs on Wednesday, August 10 at 9:00pm ET
From chariot wheels of ancient Egypt to hard disks in a computer to the wheels on a Mars rover, machinery can't function without lubricants. And in today's technology, there are a mind-boggling number of friction points that must be lubed, and a staggering number of lubricants-- petroleum motor oils that keep car engines from burning up, synthetic greases that stay put in the zero gravity of space, and solid coatings that prevent eggs from sticking to a pan. We'll see how this marvel of chemistry works and how it's used. Peering into the future, we'll behold a power generator that employs air as a lubricant, trains using magnetic levitation, which eliminates any need for lubrication, and bio-engineered vegetable oils that promise to take humanity back to one of its very first lubricants. From helping medieval windmills spin, to allowing robotic arms on planetary rovers to move, lubricants are crucial to the advance of technology and literally keep the wheels of progress turning. TVPG
I've heard on other forums that they will be interviewing American Airlines and the primary focus of the show will be synthetic lubricants. Even heard a rumor Amsoil might be disucssed.
Old Aug 8, 2005 | 10:16 PM
Texan1's Avatar
Q50 Red Sport 400 RWD
It is ok to go six mo. on oil change interval--provided you dont go over on miles.
ghost_g35
Aug 7, 2015 10:31 AM
tiguy99
Jul 26, 2015 01:39 PM
lemmy999
Jul 25, 2015 12:13 PM
