Remove B pillar ?
Old Aug 6, 2005 | 07:09 PM
NonAme's Avatar
div?
Old Aug 6, 2005 | 09:53 PM
doogie's Avatar
I got 80% of the way. My method was "pull" "pull" and "pull". Remove the door trim by pulling it away, then remove the bottom section. it takes some strong pulling, as it uses these uber-**** metal clips. (Be sure not to lose these, i lost one but it didn't seem to matter when putting it all back together)
Then you have the top left. I was able to remove the top from it's clips but could never figure out how to remove it with the seat belt in place.
...And I never fixed the rattles.
Old Oct 24, 2005 | 08:56 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Another option is to use some B-Quite or Dynamat;
That will stop the vibration in the panel which will stop the buzz.
Worked 4 me.
Old Oct 24, 2005 | 11:05 PM
PotomacG's Avatar
Originally Posted by andycon
OK, I got hold of a manual and... it's easy!
Listen to the man DIYers. Get the bloody manual. It saves money, grief, time, your sanity and lots more.
Old Nov 9, 2005 | 01:03 PM
whyjay91's Avatar
I ended up inserting some small industrial-strength sticky-back velcro (fuzzy side) under the sliding section. That stopped the awful buzzing noise! Yay!
Could you elaborate on the 'sliding section'? I'm getting it now too and am looking to take care of it.
Are you speaking of the section inside the pillar where the belt can be adjusted up and down?
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
dcsbh1
Oct 1, 2015 03:15 PM
