What is this sign
Old Aug 15, 2005 | 12:12 PM
basus's Avatar
What is this sign
just above the temperature with a semi circle with an exclaimation sign inside the circle , just came on this morning and i am at work and did not have a chance to read the manual ... can u guys pl let me know
thanks a lot
Old Aug 15, 2005 | 12:18 PM
FrizzleFry's Avatar
low tire pressure
Old Aug 15, 2005 | 12:21 PM
basus's Avatar
do i know which one has low pressure
Old Aug 15, 2005 | 12:24 PM
SDG35619's Avatar
just check them all...
Old Aug 15, 2005 | 03:13 PM
Nickk6's Avatar
You should know
Old Aug 15, 2005 | 03:14 PM
Msedanman's Avatar
O.F. Administrator
Your system doesn't show which one(s) are low or high, so you'll have to check them all.
C.
Old Aug 15, 2005 | 03:38 PM
big daddy d's Avatar
why are you asking me? I've never even seen your car!
Old Aug 15, 2005 | 04:02 PM
basus's Avatar
Thanks a lot guys .. i checked the tire pressure and all the 4 had pressure between 30 to 31 and i filled it up till 33 and the light is gone
Question is that is the sensor suppose to give an indication when the tire pressures are slightly below normal
Old Aug 15, 2005 | 05:29 PM
jaspergtr's Avatar
have you changed any of your tire settings, i.e. aftermarket rims, coupe swap, changed a single tire, or anything?
Old Aug 15, 2005 | 07:47 PM
basus's Avatar
No - i have not changed anything
Old Aug 16, 2005 | 07:03 AM
skeleton_cru's Avatar
Sedan
Take a look in your owner's manual. All you need to know is probably in there.
dcsbh1
Oct 1, 2015 03:15 PM
SuperSaiyan
Sep 23, 2015 06:13 PM
wayneside
SouthEast
Sep 23, 2015 06:38 AM
wayneside
NorthWest
Sep 23, 2015 06:24 AM
