05 6MT goes green. 25.2 MPG 2nd gass tank
Old Aug 19, 2005 | 02:05 PM
Msedanman's Avatar
O.F. Administrator
Originally Posted by AgisA
I just finished my secong gass tank. From filling up, no overfill, to warning red light on gause appearing ~ 16.5-17 gallons. I did 428 miles.
75% freeway, 25% city
shift always before 2500 RPM, mostly aroung 2000 RPM.
G has 700 miles. Freeway speed ~ 70 MPG.
When warning light appeared display on NAV saaid 55 miles to empty.
I am pretty happy!. I am shooting for 28 MPG after break-in and 95% freeway.
My 03 maxima 6 speed can do 30 MPG on the freeway.
Pearl white + wheaat. NAV, 6 MT
That's decent mileage. I got much the same on my '03 Sedan and was quite happy with it. Only problem was no 'playing', and low cruise speed (60) since anything above that seriously cuts into economy.
My 02 Max was capable of very good mileage too, about 10% better than the Sedan.
Kudos.....good mileage these days is a plus.
C.
Old Aug 19, 2005 | 03:50 PM
ZXiMan's Avatar
Originally Posted by TBone24
ZXiMan,
Do you have more info or have you already posted on your EVO350 gear mods? I would love to knock the gearing around so sixth gear isn't so damn short, spinning at 3000 at 80mph!
I posted on my350z.com in the modifications area about the gear swap... it is current today
Old Aug 19, 2005 | 10:17 PM
gtbigup01's Avatar
Yeh!
It's fun revving the engine to 4000-5000 RPM and shifting but why do all the time?
I enjoy smooth shifts under 2500 RPM as well and the G moves well, plenty of torque there. Once in a while I will push her but why waste all that gas doing it all the time?
I prefer running the car lean and push it when necessary. Then I get to enjoy its power more.
By the way, freeway speeds of 70 MPH seeem to give me good gas mileage consistently; at least 26 MPG and car has only 700 miles.
Also I notices MPG indicator on NAV display is pretty accurate
I concur with your freeway MPG. I just came back from Alabama a few months ago ( 8hr trip) and drove 75 -78 the entire way and yielded 26.36 MPG I was happy. Npw if only I can get more than 17MPG city I'd be really happy with my 04 6spd. sdn.
Old Aug 25, 2005 | 07:24 PM
yofool's Avatar
YoFool. Don't shift so early or you will fxxk up the motor. Don't be a smartass trying to save some gas and fxxp your motor.
Old Aug 25, 2005 | 08:42 PM
MrBig's Avatar
It works on my machine
How would shifting @ 2500 mess up your motor? Do you know this for a fact? Were or are you a mechanic? I was for 10 years. If your ever in an automatic and your driving "normally" in normal traffic do you think the tranny ever let's the RPM's get above 2000. In my opinion, if a motor with an auto trans is not messed up from "normal" driving, there is no reason why a motor with a manual trans should ever be messed up from shifting @ 2000 - 2500. IMHO
Old Aug 25, 2005 | 08:52 PM
basus's Avatar
Defintely it may damage the transmission as you are driving in 3rd and 4th much below the recommended speed and how do you manage to shift below 2500 rpm , in that case there is no fun at all in driving a stick
Old Aug 25, 2005 | 09:09 PM
JKWright's Avatar
It won't.
No he does not.
If he was, he was the worst mechanic who ever turned a wrench.
My apologies for the harshness. I have no patience for people who present fallacy as fact. Here's the latter: Shifting at any point in the rev range that does not lug your engine will not hurt a thing. The VQ35 in my 6MT happily pulls as few as 1000 rpm -- maybe less -- at light throttle in higher gears while accelerating smoothly and without protest. Won't hurt a thing.
Really, people. If you don't know what you're talking about, why post messages like these that present your "ideas" as law? All you're doing is misleading the less technically informed folks here and killing your credibility.
Old Aug 25, 2005 | 10:15 PM
jawjaw's Avatar
It hurts your trans. and engine if you shift early? WTF? Yeah - if you shift into reverse at 30mph. That just doesn't make any sense.
Old Aug 26, 2005 | 09:20 AM
MrBig's Avatar
How?, please explain.
Um, not be a pr!ck but the general steps are push clutch, mover shift lever, slowly release clutch.
I agree 100%, but the topic is getting the best MPG, not the fun factor.
Old Aug 27, 2005 | 01:52 AM
AgisA's Avatar
Check the 05 manual!
Manual suggests you shift at about 2000 RPM or below for max gax savings.
I have been driving more agressive lately, shifting 2500_3000 RPM but gas mileage still pretty good. Finished break-in period. I am pretty happy with gas mileage . Its about the same of 6 MT 03 Maxima
Old Aug 27, 2005 | 01:29 PM
dbarnes's Avatar
AgisA:
Congratulations, you have undoubtedly taking the title for "Best MPG In A G35 6MT Sedan", and are to be commended for your conservation and constraint.
Conversely, science tells us that "for every action there is an equal and opposite reaction", and alas, methinks you have also garnered the crown "Least Fun Wrung Out Of A G35 6MT Sedan", as well!
Just kidding AgisA. I, too have found that "short shifting" is easily done with the "G", and do it often when I don't want/need hard acceleration, but I just don't have your self-discipline to stay out of the throttle for a whole tankful
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
BradMD_96
Oct 6, 2015 09:31 AM
Hogbone
Sep 28, 2015 06:44 PM
Claudiu
Sep 26, 2015 01:04 PM
