G35x suspension options
Old Aug 19, 2005 | 05:00 PM
killerlexus's Avatar
what springs can be put on the G35x? and how much of a drop would i get? since the X sits higher then the other G35's is it ok to go with a lower drop spring like tein S tech? and does the front sway bar fit the X? what do u recommend for a rear sway bar.
Old Aug 19, 2005 | 06:59 PM
nr2134's Avatar
Dont be lazy and use the search function. Ill be nice and answer your question anyways.
G35X Suspension options = NONE
Old Aug 19, 2005 | 07:40 PM
Lip's Avatar
Lip
There are some threads in here- Example:
https://g35driver.com/forums/showthr...ension+options
There are no specific X model options- The Lower control arms are different, though I'm not sure what will fit and what doesn't fit.
Springs shouldn't be a problem, dampers shouldn't be a problem.
zoop425
Mar 29, 2016 05:51 PM
Team STILLEN
Aug 10, 2015 08:17 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
kinetek
Aug 3, 2015 04:25 PM
atk08
Jul 30, 2015 03:12 PM
