small oil filter
Old Nov 6, 2005 | 09:46 PM
Triple8Sol's Avatar
Originally Posted by eeaton
I use the K&N oil filter on my G. I use the HP-1008 K&N filter, which is the same small size as the OEM filter. I read somewhere that it will also take the HP-1006 K&N.
The HP-1006 K&N is for the '99 Maxima. If you guys are using the OEM Nissan filter for that Max, then this K&N version should work. I bought it today, so we'll see...
Old Nov 13, 2005 | 08:18 PM
GSGNG35's Avatar
Originally Posted by escotch
why do you buy a 15K oil and dump it at 4k then 5k? it's a waste. do you drain your gas tank if you don't use it all in a week?
If the oil was not changed in 15000 miles you would be adding so much between changes to account for another oil change.
Old Nov 14, 2005 | 04:22 PM
Msedanman's Avatar
O.F. Administrator
The small filter on the VQ is the nature of the beast.....looks puny but Nissan must figure it's big enough.
I also used the Nissan maxima filter which is slightly larger. # 15208-9E000.
C.
Old Nov 14, 2005 | 05:02 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
How much do you add between changes??
Maybe I'm just lucky but mine doesn't consume enough to see it on our wacky dipstick.
Old Nov 15, 2005 | 09:28 AM
ryoken's Avatar
Let me point ya'll at this discussion as it occured a couple of years ago. This post also contains various brand filter model #'s for both the OEM and the larger size filters.
Other thread: My first oil change! (Not mine, somebody else's... )
celwin
V36 Engine, Exhaust, Drivetrain & FI
11
Sep 28, 2015 03:52 AM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
johnadlertech
Engine - Complete Motors
Sep 6, 2015 12:45 PM
UT G35
Sep 3, 2015 03:58 PM
