Help on offset and rims fitment
Old Sep 19, 2005 | 05:18 PM
Sceptre's Avatar
I have a 2000 Acura TL w/ 18x8 Iforged FLux. +53 offset.
I'm thinking about getting a G35 sedan and wanted to know if these wheels will fit.
I tried to do a search, but it did not prove fruitful. Any help would be appreciated. Thanks in advance.
Old Sep 19, 2005 | 06:15 PM
bert039's Avatar
It'll fit, the TL's run 5x114.3 like we do. Its just that your offsets are a little off on the high side. It definitely will not rub, if thats what your worried about.
Old Sep 19, 2005 | 11:56 PM
Sceptre's Avatar
Yea, i know the lug patterns will fit, I'm wondering if it will look stupid because the offset is so high, plus if i drop it (prob Teins H.Tech springs) will it rub.
Thanks for the help.
Old Sep 20, 2005 | 09:07 AM
Chico's Avatar
It would look too tucked in. I wouldn't put them on. The OEM offset is +45 and what you want to do is fill the wheel well better by getting a +35 to +38 offset on a 8" to 8.5" rim all around if you're not gonna stagger it.
Old Sep 20, 2005 | 09:06 PM
skeleton_cru's Avatar
Sedan
The offset is too high. The tires may even rub the suspension in the front. If you are dead set on these wheels you could try wheel spacers, but I think you are better off getting wheels with the correct offset.
KruZZe
Feb 27, 2023 05:04 PM
the93owner
Oct 4, 2015 09:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
TurTLe*
Sep 29, 2015 01:43 PM
