Time for rims... But what size to go with?
Old Sep 19, 2005 | 06:22 PM
EverybodyWildOu's Avatar
I'm not sure what size I want. I'm thinking 18s mainly cause they're cheaper and eventually, I might lower my car. But do you guys think 18s are too small? Whats your opinion?
Old Sep 19, 2005 | 07:06 PM
ryansg35's Avatar
Future Sedan Freak
i have 18's with tanabe df210's (1.5 drop all around) 18's are perfect for me
Old Sep 19, 2005 | 07:08 PM
codeflux's Avatar
18 x 8.5, offset +40. make sure you get the correct offset!!!
Old Sep 19, 2005 | 08:13 PM
Teeter's Avatar
Just depends on "the look" you want. To me, 19's often look a bit out of place on the Sedan. Unless you're going for the total sports car look. I think that 18's give a very sporty, aggressive look but can retain some of the "refined" Sedan profile.
-T
Old Sep 19, 2005 | 08:45 PM
Chico's Avatar
If you want to stay with 18's and want a nice agressive, flush look for an excellent price....get the Coupe 18's. I will be putting those on for the winter with Blizzaks 235/45/18 all around. Obviously in your case you'd get high performance tires.
Here is a pic to give you an idea.
Old Sep 19, 2005 | 08:50 PM
well what are the maximum and minimum offsets I should get?
Old Sep 19, 2005 | 09:11 PM
perry05G35's Avatar
I have the same color G you have is your car lowered?
Old Sep 19, 2005 | 09:35 PM
Chico's Avatar
That's not my car in the pic. But I also have a BS and is lowered with the Eibach pro kit.
Old Sep 19, 2005 | 09:55 PM
jasonsfa98's Avatar
Hey Ryansg35 ...
Is that your car pictured? Did you install the lowering springs? Was it difficult?
Old Sep 20, 2005 | 02:43 AM
ryansg35's Avatar
Future Sedan Freak
Originally Posted by jasonsfa98
Hey Ryansg35 ...
yes its my car
i had it professionally installed by signal auto where i live. took them about 30 mins to do.
Old Sep 20, 2005 | 02:56 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
It depends if you want a staggered setup or all the same offset. Personally i would get all the same offset if you are going with the 18's so you can still rotate the tires, in turn giving them longer life. If your gonna go with 19's i would go with a staggered setup. +40mm offset up front and somewhere between 25-35mm offset out back.
Old Sep 20, 2005 | 09:01 AM
Chico's Avatar
That's not right!! Eventhough the front would fit, the whole set up would look odd.
Here is what I recommend if you're gonna get 19's staggered.
19x8.5 +35 to +38 w/ 245/35/19 front
19x9.5 +45 w/ 275/30/19 rear
Non-staggered:
19x8.5 +35 to +38 w/ 245/35/19 all around
Old Sep 20, 2005 | 09:59 AM
big daddy d's Avatar
Chico, as always, is EXACTLY right.
What rims are you thinkin' of?
As Chico knows.........I love to look at the rims guys are lusting after
Old Sep 20, 2005 | 11:59 AM
To tell you the truth I'm not sure what rims I'm looking for... Money is always a big factor for me. So if you guys know of any good deals, let me know!
Old Sep 20, 2005 | 01:01 PM
shodog's Avatar
visually the 19" will look better on the sedan. It fills the wheel wells out better. IMO the 18"s look small
