SLIP and VDC light no acceleration! HELP!
Old 04-18-2006, 02:33 PM
MEXTEP's Avatar
I had the same problem and also took it to the dealerCerritos Infiniti and they took care of it.
Old 04-18-2006, 03:11 PM
dirrtybear's Avatar
raises all-in
Dealer just got back to me and said they ordered a new throttle body for me and it's covered under warranty.
They didn't say a peep about my K&N filter or Z-tube, even though I told them about it.
Old 04-25-2006, 11:36 AM
OG35's Avatar
Not sure if this the same exact problem...
This just randomly started about a week ago in my 2003.5. While driving, or accelerating, the Parking Brake light, SLIP light, and VDC light all come on and stay on. But the difference here is that I don't lose any acceleration. I can drive normally, but all the lights are on for some reason. Eventually the Parking Brake light will turn off, but the other 2 remain on. Is this related to the throttle body as well? And how much will the dealer charge me since I am out of warranty? Please advise. Thanks.
Old 04-25-2006, 10:22 PM
randystyles's Avatar
had this problem, all i had to do was adjust the little screw counterclockwise on top of the throttle body, its a black screw and theres a nut locking it in, adjust it one turn at a time and disco the bat every time, drive it around till its ok again
Old 05-02-2006, 08:27 AM
dumberfeet's Avatar
I get the same thing on my 05 6mt coupe, the VDC, SLIP, ABS, and later on the ABS light, is this the same problem with the throttle body?
Old 05-05-2006, 11:32 PM
waterp7's Avatar
You can add me to the list too...all lights went on (CEL, SLIP, VDC) right when i started the car....and the service departments all closed at 7PM so I couldn't schedule an appointment...lucky me...
Old 05-05-2006, 11:38 PM
BlackOutG's Avatar
mine happens when i do 360...all i have to do is just turn off the car and turn it back on
Old 05-07-2006, 09:34 AM
dumberfeet's Avatar
I went to the infiniti dealer here in sfla, they could not find anything with the scanner, but what they told me is that they resetted the computer on the car and that it'll hold the codes for the next 50 key cycles, no code came up for these lights, but I did hear the tch and service coord. talking bout code 2025?? not even sure that was it... but the told me that if it was a 2025 nothing could be done.... anyone have a clue of that they're talking bout??
Old 05-07-2006, 10:50 AM
glennp_1999's Avatar
TPS needs to be replaced.
Old 05-08-2006, 11:53 AM
OG35's Avatar
How much is it to change it? Warranty is gone.
Old 05-08-2006, 12:38 PM
dumberfeet's Avatar
Well I'll Be There This Saturday Again Or Before, The Lights Went Off Again On Sunday And The Low Tire Pressure Came On This Morning... Also Does Anyone Know If The Paint Is Covered Under The Warranty??? The Front Bumper Right Arround The Access Holw For The Tow Bar Is Peeling Off!!!!
Old 07-03-2006, 12:37 PM
dmitrius's Avatar
Hey guys im new member here. Been checkin out this site and it rocks! Where is the throttle body located cause i ran into the same problem once and figured i could tighten up the bolts.
Old 07-03-2006, 02:00 PM
Msedanman's Avatar
O.F. Administrator
Originally Posted by heetenism
Something is terribly wrong with my car! i have had it for 6 months.. has anyone else had this problem? the SLIP and VDC off light come on and the car has no acceleration.. this happens sporadically.. dont know why? is the transmission screwed? any advice is appreciated.. think i have a lemon.
Something in the system has failed and caused the computer to go into "limp-in" or safe mode.
Have the dealer look at it, and if it's not driveable, they'll tow it for you.
C.
Old 07-03-2006, 02:02 PM
BlackOutG's Avatar
it happens when your breaks need to be changed
  #30
Old 07-04-2006, 12:32 PM
mhollinger's Avatar
I feel a bit left out. I had the slip and VDC lights come up last week. When I took it in, the tech I spoke with suggested it might be the throttle body.
According to the work performed, "Found ground wires loose; secured loose ground wires per tsb."
That might help you when you take yours in; it might not...
Quick Reply: SLIP and VDC light no acceleration! HELP!
